It is currently Sun Aug 17, 2025 6:20 pm
PostPosted: Sat Aug 27, 2005 9:05 am
I based this jig of of something I saw in Julius Borges' shop. It took only about 20 minutes to build and made the job of lacating the bridge so easy that I'll take the time to make one of these for every scale length I use.
First, here's a drawing:
I used a drawing be cause the jig is polycarbonate and hard to photograph.
First I cut a piece of 3/32" polycarbonate to 3" x 26".
Next I clamp a straight edge to the center of the strip and score a line down the middle with an X acto knife.
Next I mark out my scale length (In my case 24.9") and with a square score a line 90 degrees to my center score.
Next I layout a line for my compensated saddle. I compensate the saddle by 1/8" at the center line.
I compensate the saddle by 1/16" at the treble edge of the strip of plastic. I chose to make my strip 3" wide bcause my saddle is 3" wide. I take a straight edge and score a line from the treble edge to the bass edge using my two compensation marks as guides. This new line is the CENTER of my saddle slot.
So far this is just like I layed it all out on paper as described in Cumpiano.
Next, I cut off a 3/16" by 2-1/2 inch piece of the 3/32" inch plastic. I sand one edge of the small piece of plastic and lightly sand a line on the other side of the platic under the score line I made for the compensation position.
I carefully clamp this small piece of plastic to the larger strip so that the score line is centered. I then wick in some solvent to glue this piece on. After 2 minutes or so I can remove the clamps. The jig is done.
Here is how you use it. Mark a center dot at on the fretboard at the nut position and at the sound hole position. Lay the jig on top of the fretboard so that the center line of the jig lines up with the center of the fretboard and the end of the jig is flush against the end of the fretboard. Clamp it down. At this point the small piece of plastic is in the exact spot that your saddle is supposed to be. Take you pre-slotted bridge and slide it up under jig so that the blastic slide into the saddle slot. The bridge will not be able to slide toward or away from the nut. It will have some play side to side. I put a center dot on the top of the bridge to line up with the center line of the jig. The jig hold the bridge pretty securely. Now you can mark around the bridge with your exacto knife.
I cut my jig so that it doesn't extend much beyoud the plastic saddle piece. This allows me to drill the 1 and 6 bridge pin holes. I use the Fox bridge clamp to mount my bridge so the pin holes are and excellent way to set the bridge position.
What I like most about this jig is that almost nothing slides around while your setting the bridge. You can accurately position a bridge in 15 seconds.
Mike Mahar38591.7561342593
PostPosted: Sat Aug 27, 2005 9:15 am
Mike, its funny you should post this, I have a simular Jig that John Hall Blues Creek Guitars donated for the OLF Auction, Ill be putting it up next week.
PostPosted: Sat Aug 27, 2005 9:20 am
I,ve got one of the jigs from Blues creek and it is a very similiar principle, but it is adjustable.
Once I recieved some instruction from John and stopped trying to use it the wrong way round , I have only had it a few weeks, and have done 3 bridge sets with it, but you couldn't part me from it, at excellant and engenius tool. Beautifully engineered
RussellR38591.7651851852
PostPosted: Sat Aug 27, 2005 12:18 pm
Hi Guys
here is the poop on my jig. the unit is laid out by the rule. You set the length. I add about .125 to the length. This helps when intonating. I tried so often to set them at dead length and never had a good result . Once I started to find the secret I kept going long till T stopped being sharp.
   With the scale set you drill 2 3/16 inch holes in the 1st and 6 th location. Wax the posts so glue doesn't form on the threads. Use the knurled nuts and lexan to glue the saddle area of the bridge . The wings are done last after you clean up the glue. Once the upper plate is on just lightly snug them on the wings. It doens't take much.
Any questions feel free to ask and I will do what I can to answer any question. I will have a OLF special right after the auction
johntippie5338591.8915740741
PostPosted: Sat Aug 27, 2005 12:38 pm
John.....
Questions questions questions...
I take it that it does multiple scales??
Can it adapt to different width's on the 1st and 6th?
and how much...
I LOVE it..
-Paul-
-Paul-
Patriot Guitars
PostPosted: Sat Aug 27, 2005 12:42 pm
The "T" string John? Man you must use some interesting tunings!!
PostPosted: Sat Aug 27, 2005 9:48 pm
Hi Paul
Yes it does different Scales.
One of the posts on the clamp slides to cope with different String Spacings at the Bridge.
PostPosted: Sat Aug 27, 2005 10:05 pm
T is TYPO. LOL
Never type after spraying lacquer
john hall
cheaper than beer and ya ain't gotta pee
PostPosted: Sun Aug 28, 2005 1:28 am
So John,
I seems every once in a while I read about a jig or tool that someone has purchased from you, but I can't seem to find it on your web site! Please, let us know about all the stuff you offer!
PostPosted: Sun Aug 28, 2005 2:36 am
[QUOTE=tippie53] Hi Guys
john[/QUOTE]
John, I don't understand yet how you use your jig. What do you mean by "glue the saddle area under the bridge" and then you glue the wings next? Once you've glued down the saddle area, how do you get the glue under the wings?
Do you mean that you tighten the clamp in the saddle area fist and then tighten the clamp on the wings with glue spread on the whole bottom of the bridge?
Does your jig line up the saddle slot or the bridge pin holes? It is hard to tell from the picture. How do you center the jig on the fretboard? You have a slot cut at the nut end but nothing further up the neck to align things.
PostPosted: Sun Aug 28, 2005 2:59 am
If I were making a jig to sell I would probably make it adjustable. However, anything that can be adjusted has to be adjusted and can be adjusted wrong. One of the strengths of my simple jig is that it is correct for 24.9" scale length and unless someone sneaks into my shop and trims off the end of the jig, it should be good.
Making a new one for other scale lengths is a simple enough job that I'm inclined to do it that way rather than make it adjustable.
PostPosted: Sun Aug 28, 2005 4:52 am
Hi Mike
What I think John means is you glue the whole thing clamp the centre then tighten the bridge wing clamps.
The jig has a piece that sits into the saddle slot.
Russell
PostPosted: Sun Aug 28, 2005 6:02 am
I like the stewmac version - fairly low tech, but it worked for me.
PostPosted: Sun Aug 28, 2005 8:04 am
I have the StewMac Saddlematic and like it for determining bridge location. However, I then use John's clamp for bridge glue up.
PostPosted: Sun Aug 28, 2005 11:57 am
   If you look at the scale the unit is adjustable. The lower end will drop into the saddle slot for assured alighment and postioning. 2 3/16 holes are drilled so the clamp can pin the bridge and keep it from moving .
    The bridge is then glued on.
   This comes up through the and then the leaxan is placed over the bridge then the knurled nuts are tighten till the lexan takes the shape of the bridge at the saddle area Now you place the upper unit on and with the nuts on the post the toggle clamps secure the wings. I hope this makes the use of this clear. If you have any questions please let me know I want you all to be able to see how this works.
PostPosted: Sun Aug 28, 2005 2:51 pm
How much is this jig for OLFers
Andy
PostPosted: Sun Aug 28, 2005 11:22 pm
   Regular price is $75 for the pair. I will do $65 for the OLFers.
    Free Shipping also.
PostPosted: Mon Aug 29, 2005 12:46 am
John can't find it on your site. Have you got a link to it?
PostPosted: Mon Aug 29, 2005 5:25 am
I'll second what Colin said. Please see my message above.
PostPosted: Mon Aug 29, 2005 6:17 am
John,
I have a suggestion on a small but important change to your clamp. Make one of the holes through which the screws go slotted 90 degrees to the direction of the other slot.
I just glued up a pyramid bridge where the pin holes were parallel to the saddle. This caused the wing clamp to be severely off center on the treble side and I couldn't make the camp pressure even. If my jig had been slotted in the other direction I could have lined it up with the bridge and not the pin holes.
PostPosted: Mon Aug 29, 2005 6:28 am
John, are the brass screws in the baseplate adjustable side to side? Or do you have to use the same pin spacing all the time so the screws will fit correctly?
PostPosted: Mon Aug 29, 2005 2:29 pm
The bridge clamp is adjustable to fit a 2 to 2 3/8 spacing. there is a cylinder the will open up.
I don't have this in the site as of yet. I am in the process of making a new face lift and I hope to have a full on line catlog on the site.
thanks for all the input. I do listen
john
