It is currently Sun Aug 17, 2025 8:01 pm
 Post subject: Nut files?
PostPosted: Sun Jan 25, 2009 7:59 pm
First name: Danny
Last Name: Vincent
I'm moving along nicely on my first build without much help from the Coach and in the new shop. I've been making what jigs I needed as I go but and bought a few fretting tools a while back but I am now in need of nut files. I'll most likely never build more than one or two instruments a year. What would you recommend for nut files. There's a couple on e-bay. Sorry, I couldn't figure out how to link. Norman files. Anyone tried them? at $50 they almost seem to inexpensive. There is another set that's always for sale there. They look petty similar to SM but about 1/2 the price. What works for you?
Thanks for the help,
Danny
 Post subject: Re: Nut files?
PostPosted: Sun Jan 25, 2009 8:09 pm
Hey Danny, I'm pretty new at this, working slowly on build #7, but I bought a set of the norman files and have been real pleased with them. Before I had only a couple of the stew-mac files, all I could afford, and it's great having the full range of correct sizes to use. They cut good and do a nice job for me. Now one of them does seem to be getting dull and doesn't seem to cut as well, and I have heard others say they don't stand up, so that may be right if you cut a lot of nuts. For occasional use I've been pleased, but I would probably get better ones if I could afford it and had enough work to justify the expense.
Joe
PostPosted: Sun Jan 25, 2009 8:18 pm
Danny bro try Pilgrim's Projects - they have Grobert and I just received mine a couple of weeks ago and think they are the best that I have ever used. And the folks at Pilgrims Projects are super nice people to deal with too: http://www.pilgrimsprojects.biz/nut.html
PostPosted: Sun Jan 25, 2009 8:20 pm
I have cut bout a dozen nuts with my norman files, I think I'll probably get another dozen out of em
PostPosted: Sun Jan 25, 2009 10:00 pm
I have the Ibanez nut file set from Allied. Not to pricey and they seem to work fine for me. No sign of them deteriorating or anything.
PostPosted: Sun Jan 25, 2009 10:32 pm
When my nut files get real dull, i break off half of the cutting section. This lets you use the fresh and sharp part of the file closer to the handle without bumping into the tuners.
Jordan Aceto
Ithaca, NY
PostPosted: Sun Jan 25, 2009 10:41 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Norman nut files are made from feeler gauge stock, I took a set of feeler gauges and cut slots across them with a dremel cut off disk, I uses them for my 1st and second builds before I got a set of proper files. If you are looking for cheap get a set of feeler gauges with radius edges and make your own. If you want a decent set for a reasonable price check out these http://www.warmoth.com/supplies/supplies.cfm?fuseaction=files I got the NFS8 set.
Fred
Fred Tellier
PostPosted: Mon Jan 26, 2009 1:27 am
Three, then they were too dull to use.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Mon Jan 26, 2009 7:05 am
I'll recommend Pilgram's Projects too. Great folks to deal with and they sell good stuff!
PostPosted: Mon Jan 26, 2009 12:44 pm
I would put the 50 bucks toward a set of better files. The NFS8 at Warmoth (see Fred's post) look pretty good and at $64, not much more than the Norman set you mentioned. The NFSB7 set look pretty good as well ($70).
PostPosted: Mon Jan 26, 2009 6:03 pm
I've had two of the StewMac double-sided files long enough to make and setup at least 50 bone and mammoth ivory nuts now. They're ready for the trash almost but I think I will try Jordan's idea and break them off and see if that will buy a little more time. Otherwise I've been happy with them.
"We might not be big but we sure are slow"
PostPosted: Mon Jan 26, 2009 7:42 pm
I use the Warmoth files and am happy with them.
Thanks for the tip about Boggs...that's about 30 minutes from me.
Users browsing this forum: No registered users and 42 guests
