It is currently Mon Jul 28, 2025 6:45 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 03, 2009 1:46 pm
I cut close to the line with a bandsaw and then clamp the side to the template and finish on the router table. I'll try to post a picture later.
Terry
PostPosted: Tue Feb 03, 2009 2:16 pm
I dont see the advantage to routing, why not just cut to the line on a bandsaw? It will be sanded later anyways, seems like an unnecessary step.
Jordan Aceto
Ithaca, NY
PostPosted: Tue Feb 03, 2009 2:32 pm
I bend (index at the butt, so the match is perfect where the sides meet), then prop up the sides - clamped in an outside mold - and mark the taper, use a small douzouki (handsaw) to cut the excess off (3 minutes), use a block plane to get close (3-5 minutes) and then bowl sand to final shape. I like doing wedged bodies, and varying the degree of taper depending on my mood/design goals, and it's actually a fun part of the process for me.
PostPosted: Tue Feb 03, 2009 3:45 pm
Just not sure how perfect the profile needs to be initially. Collin has an image in the thread he linked in which the side sits perfectly in the dish.
PostPosted: Tue Feb 03, 2009 3:54 pm
Whether you bandsaw or rout to a line, it is still the same line. Collins picture looks perfect, it doesnt matter if the edge of the sides is jagged from a saw blade or smooth from a router.
In practice, it does not take much time to sand out little localized high blips, but it takes forever to sand the entire rim set down to reach a low spot.
Jordan Aceto
Ithaca, NY
PostPosted: Tue Feb 03, 2009 8:24 pm
The only advantage I see to routing is that the profile is close enough that I'm comfortable gluing the kerfed lining before hitting it with the sanding dish. That means I only radius sand once. I must admit I frequently think about skipping the routing if I get a nice cut with the bandsaw. Just takes a couple of minutes though so I'm still doing it.
Terry
PostPosted: Tue Feb 03, 2009 8:49 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I use Colin's method, and have found it to be fast and accurate. Now that I am building multiple
sizes, I'm starting to make hard templates for each size. Before I just kept the piece of blue
masking tape for each size, and re-stuck it down on the sides using a straight edge on the
inside edge to keep the profile accurate.
Gene
PostPosted: Tue Feb 03, 2009 9:01 pm
Terry
Only sanding once does sound worthwhile...
Jordan Aceto
Ithaca, NY
PostPosted: Wed Feb 04, 2009 4:05 pm
Colin,
Thank you. That's going to save me a lot of trouble.
Walter Lay [clap]
Walter Lay
"It's taken me so long, but now that I know
I can see. All that I do or say, is all I ever will be"
- Billy Joe Shaver
