It is currently Sun Apr 26, 2026 11:41 am
PostPosted: Mon Mar 16, 2009 11:08 am
First name: Daniel
Last Name: Henriks Madureira
Country: Close to the great white north
Hi everyone,
I'm currently in the process of building an electric guitar from scratch, and i'll be using the above mentionned setup.
Would somebody be kind enough to load my programs and check for possible sources of error?
Ideally somebody of the same kind of setup that i'll be using.
Here are a few samples of the whole process so far.
I'll glady supply the final programs if someone desires to use them for personal use.
Thanks in advance
CNC is a tool, not cheating :)
Last edited by Puresoundguitar on Mon Mar 26, 2012 7:45 pm, edited 1 time in total.
PostPosted: Mon Mar 16, 2009 3:45 pm
Last Name: Garrish
What CAM software are you using? I can see you've got CATIA there (must have a neat day job!) but are you using it for the toolpaths or just the CAD? Most CAM software has simulation which will let you check your paths, but if yours doesn't then you'd need to find someone with third-party simulation software like Vericut or Metacut (which is rare) to check the paths.
Bob Garrish
PostPosted: Mon Mar 16, 2009 7:08 pm
First name: Daniel
I'm actually using Catia as my CAD and CAM software. I can do my simulations to a certain level, but i was looking to test my programs in the closest possible to reality environment.
I have Vericut at work, but it would be a real pain to configure it properly with all the correct machine specs.
As you know, every machine controller as it's own `soul`, i mean certain aspects that are unique to every controller. I know Xilog and SCM machines are no exception, that's why i'd like to have a real life test.
If you think you can give me a hand in any way, just let me know.
Thanks in advance
PostPosted: Tue Mar 17, 2009 1:00 pm
First name: Nelson
Last Name: Palen
I can't help you on the verification but do have a suggestion.
Make mockup blanks from cheap wood to check the programs.
I would bet that you'll see something that you want to change.
Nelson palen
PostPosted: Thu Jun 25, 2009 9:49 am
Hi,
I have an SCM Record 220 with Routolink (Xilog 3) control,
i'm happy to help out with whatever you want
Regards
Paddy
PostPosted: Thu Jun 25, 2009 11:07 am
PaddyD wrote:
Hi,
Regards
Paddy
That's quite a machine Paddy!! What are you doing on it? Good to see you posting here again as well!
PostPosted: Thu Jul 02, 2009 11:24 am
Shane Neifer wrote:
PaddyD wrote:
Hi,
Regards
Paddy
Hey Shane!!! you can't keep a good Paddy Down!! I am using the machine for everything (well not coffee etc.....) its great, made in 1999, weighs in at just over 19000lbs!! two aggregate heads, and a 10hp spindle......... its a big brute, but perfect for body and neck making.... also chews through radius dishes quite nicely!!
i'm feeding it with code from mastercam, which is in turn fed by models from solidworks, all good stuff!
yeah it has been a long time since i posted on the OLF, but i'm back, i guess i just got a bit dissillusioned with the same old arguments going on all time, but what can i say...... i missed you guys!
P.s Shane hows the Lutz Coming? any luck with harp guitar sets?
Paddy
