It is currently Fri Apr 24, 2026 5:14 am
PostPosted: Mon Apr 13, 2009 7:02 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Zip/Postal Code: 45150
Country: U.S of A
I just got a 1.25 hp Craftsmen router and table and was wanting to know, what most use for solidbody edges and electronic spaces.
Thanks in advance
Daniel
PostPosted: Tue Apr 14, 2009 2:11 am
Last Name: Cyr
City: Roseville
Thanks in advance
Daniel
Get the 3/8" diameter and 1/2" diameter x 1/2" cutting depth bits from Stewart MacDonald for routing pickup and control cavities as well as neck pockets. These bits have a ball bearing that goes on the bit shank above the cutting portion of the bit to follow a guide template. Stewart MacDonald and others make special templates for the most popular types of pickups - you'll need some of those too.
Get 3/8" radius and 1/2" radius roundover bits for rounding the edges of the bodies
That's the basic
---Steve
PostPosted: Tue Apr 14, 2009 10:31 am
First name: Erik
Last Name: Hauri
State: Maryland
For some pickup routs you'll want a 1/4" diameter straight bit - run the shaft up against the template instead of a bearing. I also use that same bit for routing out truss rod channels on the router table.
For body edges I almost never use a straight router bit with a template - I've had too many instances of tear-out. Now I just bandsaw close to the line and fair it out on a spindle sander.
Then I'll go to a roundover bit on the router table.
The member formerly known as erikbojerik....
PostPosted: Tue Apr 14, 2009 12:17 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Country: U.S of A
Thanks guys. Some bits are more then what i Paid for the router
PostPosted: Tue Apr 14, 2009 12:38 pm
Last Name: Cyr
City: Roseville
My go-to router was free. I went to Sears to buy a router table, and picked out the one I wanted. It was available in two forms: 1) router table by itself for $99.99, and 2) Router table with router for $99.99. So the router was free.
The most I've ever paid for a router bit is about $30 I think.
I don't use a router to trim the bodies to shape either - I use the same method as Erik - trim to approximate shape on the bandsaw, then clean it up with the oscillating spindle sander.
--Steve
---Steve
PostPosted: Tue Apr 14, 2009 7:06 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Country: U.S of A
That sounds like a pretty good deal.
Erik:
What size round over bit did you use on the guitar in your profile pic?
That's pretty much the size I'm looking for
