It is currently Thu Aug 07, 2025 4:38 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 13, 2009 5:17 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've glued a top on the back side of the rim, but the funniest one was carving a neck. I've got a nice drawknife that was my Great Grandfathers. I keep it real sharp. I cut a neck blank completely in two with it.
Tool definition: Random orbit sander, a tool used to ruin a piece that should have been sanded by hand.
PostPosted: Wed May 13, 2009 2:27 pm
I remember one of my first guitars, I was routing a center back seam strip with a wooden guide piece that was dead straight.....well when I finised gluing in the center strip I was proud as could be, until I eyeballed down the finished piece and in horror saw that it had a nice bend to it......I had inadvertantly used the unfinished edge of the guide piece instead of the perfectly straight edge, Oh Boy duh
Gwaltney Guitars
PostPosted: Thu May 14, 2009 2:43 pm
Too many to list. oops_sign
Glued on fretboard without truss rod.
Drilled 2 1/8 end-pin pattern instead of 2 1/4.
Made 1 11/16 nut width instead or 1 3/4.
Routed neck block mortise through the back instead or the top (well almost)
Put fretboard markers on wrong frets.
Used fret board as supplied without cutting off above zero fret. (I thought they did it already.)
Glued on fretboard with out truss rod.
Put CA on finish sand through.
Let squeeze out epoxy for bridge cure on finish.
Sanded through rosette.
Chiseled through top while carving braces.
Put fret side markers on wrong frets.
Drilled end pin hole too large for end pin.
Used hygrometer without calibration. (Can you say concave top?)
Made a neck to thin and the truss rod came through after a year. (Twice)
And that was just one guitar! (not really. :lol: )
OK - That's enough for now.....
Is there ever and end to these screw ups? [uncle]
PostPosted: Thu May 14, 2009 4:24 pm
I had a sig here shortly after I first joined OLF that went something like this:
new build
mistakes circle above
waiting to descend
Some builds I swear that's what's happening.
I think it came from a chess champion's haiku, uttered at the start of a tournament.
PostPosted: Sun May 17, 2009 1:37 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
Keep a clean workspace - especially if you own cats - cats don't necessarily know the difference between cat litter and saw dust duh
Fortunately learning this "only" cost me about 1 bf of a birdseye maple board and not some nice tonewood :D
Christian
