It is currently Sat Aug 02, 2025 12:02 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 15, 2009 6:43 pm
Bill Hodge wrote:
L. Presnall wrote:
Good council...Andy, John, and David are the luthier equivalent of the Three Wise Men...by the way John, did I leave my jar of Myrrh at your place? :D
Hey L.P.,
I've got some Frankincense & Myrrh in case you can't find yours. ;)
Sweet Bill! [:Y:] I love the smell of Franincense in the morning! :D
PostPosted: Fri May 15, 2009 8:16 pm
Paul,
Are you sure it needs a neck reset?
You have said in one of your posts that the neck is bent, a neck reset will not fix that.
A neck reset adjusts the neck angle not the neck bow.
Get the neck straight with a truss rod adjustment first then evaluate the need for a neck reset.
PostPosted: Fri May 15, 2009 9:48 pm
Here you go. I'm betting this is probably what it looks like in there -
I didn't have enough clearance on the bandsaw, so I just cut through the body at the waist - it makes neck removal a piece of quiche on these.
And Larry - though I'm flattered you would consider me as one of the "Wise Men", if you think about it I'm sure you'll have to agree that I'm much more like one of the donkeys they rode in on.
PostPosted: Sat May 16, 2009 10:17 am
First name: Jonathan
Last Name: Jones
City: Nuneaton
nevemind, did see that there was a second page with a photo... :oops:
thanks
Jonny
"Anything that happens, happens. Anything that in happening causes something else to happen, causes something else to happen. Anything that in happening happens again, happens again. Though not necessarily in that order." Douglas Adams
PostPosted: Sat May 16, 2009 10:21 am
You're too hard on yourself Dave! I think you're very wise...now myself, I've been told I'm at best, a wise donkey! :D
PostPosted: Sat May 16, 2009 12:03 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
David, a chainsaw will work without cutting through the waist, and IMHO you're one of the wise men. When you talk I listen.
PostPosted: Sat May 16, 2009 6:42 pm
The punch line was supposed to be "Now that you mention it, you are a wise ass!"
Everyone must be breathing too much fresh air this weekend or something...
PostPosted: Mon May 18, 2009 10:52 am
Jeff Highland wrote:
Paul,
I'm going to measure everything again and post some pics.
PostPosted: Mon May 18, 2009 12:18 pm
Now that's funny.
If the truss rod won't take out the bow, you might be able to remove the frets, level the fretboard, refret and do a set up. While this should be done by an experienced person, it is still easier than a reset, I think.
