It is currently Sun Jul 27, 2025 7:07 am
 Post subject: 3° or 5° reamer?
PostPosted: Tue May 19, 2009 12:16 pm
Last Name: Carpenter
City: Zigzag
State: OR
Which would be the most practical taper to get. I was leaning towards 3° but it seems that commercially available end pins tend to be 5° and I don't want to shell out for both.
thanks, Bob
(plus, it seems that Grizzly sells a 3° for significantly less pesos...)
If brute force doesn't work you're not using enough of it!
 Post subject: Re: 3° or 5° reamer?
PostPosted: Tue May 19, 2009 12:41 pm
Hi Bob. You're going to need whichever matches the taper of the pins you plan to use. If you see yourself using 5 degree pins, get the 5. I use 3 degree pins, so I have a 3 degree reamer.
PostPosted: Tue May 19, 2009 2:12 pm
City: Zigzag
State: OR
Thanks James! Bob
PostPosted: Tue May 19, 2009 3:04 pm
Bob, save your money and forget the Grizzly reamer. Get a good one from LMI or SM. Also LMI sells all kinds of 3 degree pins.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue May 19, 2009 6:35 pm
Get your reamer from a machinist supply like ww grainger or MSC. The grizzly reamer isn't worth the shipping charges.
PostPosted: Tue May 19, 2009 8:27 pm
City: Zigzag
State: OR
Good information gang, I had my suspicions about the Grizzly one but though I'd fish around.
thanks again, Bob
PostPosted: Wed May 20, 2009 6:09 pm
First name: Blain
City: Leander
I third that the Grizzly reamers aren't very good. I bought their set and then bought one from LMI or Stew Mac (can't remember) and it's a day and night difference.
Blain
http://www.ullrichguitar.com
PostPosted: Wed May 20, 2009 6:33 pm
4th on the Grizzly.
5° can leave a small enough hole on the bridge plate side that some string ball ends don't go through readily. Not an issue with 3°.
