It is currently Sun Aug 17, 2025 12:43 pm
PostPosted: Wed Sep 14, 2005 1:25 pm
State: ON
I am wondering what the dimension are for the neck blocks you guys are using?
I have been working at getting the weight down on my guitars and am wondering how small I can get the block. I started with a blank yesterday and after some sanding ended up with a bock that is 2.5 in. wide and 1 in. thick, with some additional wood trimmed of the corners which are not glued to the sides. Is this to small?
My neck joint is a 14 degree dovetail that is cut a little under ? in. into the block. The dovetail is secured with 2 bolts, instead of gluing that joint.
Any thought would be appreciated.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
