It is currently Sat Jul 26, 2025 7:01 pm
PostPosted: Sun Jul 26, 2009 11:00 pm
Last Name: Cox
Hey all
I have made the radius dish plunge....
I am now in need of sandpaper -- What do you guys use?
Big sanding discs?
Sticky back roll paper?
Regular sand paper + adhesive (What kind, so far it all peeled off on me)
Then... Where do you get it?
PostPosted: Sun Jul 26, 2009 11:21 pm
John,
I have 80 grit specially made for dishes, 24 inch diametre for $20 per sheet. Piecing bits together (like floor sander paper) just does not work, I tried it. John at Blues Creek might have it for a bit cheaper.
PostPosted: Sun Jul 26, 2009 11:25 pm
I get mine from mcsdirect.com and order sanding belt in 24 inch width and 60 inch length. I ordered 80 grit Aluminum oxide. For $23.00 its enough to cover two dishes with a bit left over. I used 3M spray adhesive to glue to my radius dishes.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Mon Jul 27, 2009 5:53 am
the paper I stock is a heavy backed sand paper stock. It has the adhesive on it . $17.50 plus shipping. I carry 60 , 80 , and 100 grit. Check out this link http://www.bluescreekguitars.com/catalo ... da038143e8
PostPosted: Mon Jul 27, 2009 8:41 am
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
i got mine from a skip at the local joinery place
used for the big belt sander
might be a bit dull some belts better than others
or you could buy a belt off them either
PostPosted: Mon Jul 27, 2009 9:37 am
First name: Randolph
Last Name: Morris
I went through this recently. John @ Blues Creek is definately the place... great paper, best price
PostPosted: Mon Jul 27, 2009 11:18 am
First name: Ryan
City: Republic
State: Missouri
I use some PSA 6" discs from Harbor Freight. Works great for for me. When a certain spot begins to wear out, it just takes replacing a few of the discs.
PostPosted: Mon Jul 27, 2009 11:27 am
I want to have two different grits for each radius so when I order the discs should I go 60/100 or 80/100? Im leaning towards 60/100.
PostPosted: Mon Jul 27, 2009 8:10 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Ed, why do you need two grits? I use the 50 grit discs (at the bottom of the hollow forms list) from LMI who is also an OLF sponsor.
Dave F.
Cambrian Guitars
PostPosted: Mon Jul 27, 2009 8:17 pm
Hey Ed, you will be very surprised at how quick even grit cuts. That is the grit I use because it is a compromise between fast cutting and smooth enough to glue to. I used to use two dishes as well, one for the go-bar deck and one for sanding but now I just one for each radius and put sandpaper on it and then when I want to glue I just put some paper over the sandpaper. So, you really only need one grit.
PostPosted: Mon Jul 27, 2009 9:36 pm
Supergrit.com.
PostPosted: Mon Jul 27, 2009 9:48 pm
Shane do you mean you use 100 grit? I only assumed I would need two grits, one for quick removal and one for smoothing.
PostPosted: Mon Jul 27, 2009 11:07 pm
Ed, I just use 80 grit. It is aggressive enough for good removal (I don't pre-profile my sides but my sander is motorized) yet it leaves a smooth edge for gluing. Even by hand with a decent dish this all you really need. My dishes are double laminated from 3/4 inch MDF prior to spinning them so once done they about 15 pounds that really helps as well.
PostPosted: Tue Jul 28, 2009 6:52 am
I agree 100% with Shane , you only need 1. I personally like the 80 grit. 60 gets to be a bit aggressive and lets feathers, and 100 is too slow. 80 is just right.
