It is currently Sat Aug 16, 2025 5:29 pm
 Post subject: Guitar Display Cases
PostPosted: Mon Sep 21, 2009 5:48 pm
I have a difficult time controlling humidity for my finished guitars and also just have them on stands in various rooms in the house so I'd like to build a display case for approximately 10 guitars to solve both problems. Does anyone have pictures of any cases so I can steal some ideas? Thanks..
If this is in the wrong forum, feel free to move it.
 Post subject: Re: Guitar Display Cases
PostPosted: Mon Sep 21, 2009 5:58 pm
I was just talking about the same thing with a friend. He found this site www.accessnsight.com which has some nice designs to look at.
PostPosted: Mon Sep 21, 2009 9:30 pm
Funny you should ask...I just built one.
After finishing my last two guitars, I was looking at with several hundred $ for cases. But also, more importantly, I'd developed a bad habit of finishing a guitar, packing it away in it's case & dust bag & moving on. I wasn't bringing them out, playing them in, learning the details of what made one better or worse than the next. Not the way to improve! I decided to try a display case for the den. (It's sometimes called the "Masterpiece Theater" room.) (It doesn't offend me.)
This is the result.It holds 6 of my guitars. (10's asking a lot, unless they're solid bodies.) The primary wood is sipo (a mahogany), with pine as secondary. Fabric interior (corduroy, on special locally). Underside top is spanish cedar (from my humidor days.....God, I'd love a cigar!) The carcase is basically glued (only) mortise & tenon joints (all done on a DP attachment, which I'm told is junk, but what do I know?). Glass is 4mm in the doors and 3mm for the side panels. The hangers, which cascade in 1/2" steps L to R, are mostly my 3/16" ss trussrod material with electronic shrinkwrap over. (The "pins" in the lower wenge blocks are inner-tube wrapped first.) They can be positioned and rotated to about 30deg.
Milton, ON
PostPosted: Tue Sep 22, 2009 7:27 am
Wow Dave, you've convinced me, I need to make one! [clap]
Yeah when you're just building and not selling, case expense adds up, and I also find myself just playing the last build, the others are buried in cases.
It's funny I've skipped over this thread a couple of times, just wasn't interested. Now I need to figure where I can clear some floor space. :D
Joe
PostPosted: Tue Sep 22, 2009 8:32 am
That case is gorgeous Dave, I want to build one some day.
PostPosted: Tue Sep 22, 2009 9:39 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I'm in the process of building a single wall case. I'll see how it goes and probably make a few more for my collection. I have NO LIVING FLOOR space for a multi case unit....but my closets are full of guitar and banjo cases.
The link listed has some nice cases.
"V" Angling 2 mirrors in the back of the wall case (with a little space on the sides and back) will make the guitar back much more viewable.
Kent Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Tue Sep 22, 2009 9:58 am
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
I can't yet post pictures here,but years ago I made a guitar case that holds 32 guitars. It is just barely able to clear the ceiling,and it has to be assembled in place. The guitars face frontwards on 2 levels,4 across on each level,and 4 deep. I put UV glass film on the glass,and carefully cleaned the glass first. The film was squeegeed on very carefully so no bubbles show at all. There is a small fluorescent light on each level,with UV tubes slid over each light.
I used metal corners inside the cabinet to be able to take the cabinet apart and move it from shop to home. With all the guitars in the case,you never notice the small metal corners inside. It's a good thing I did,as you would never get the cabinet through a doorway,nor would you be able to tip it up into position as it would jam against the ceiling. Plus,we moved about 5 years ago,and had to bring it here.
All the glass is plate glass. The wood is white oak.
PostPosted: Tue Sep 22, 2009 11:06 am
Dave, that is awesome - a beautiful way to display your work and keep it safe from dogs, cats, kids, and humidity.
Thanks for the inspiration. I look forward to building one of my own.
PostPosted: Wed Sep 23, 2009 1:51 pm
Here is another site with some examples if anyone is looking for ideas. By the way, that is a fine looking display case and some nice looking guitars.
http://www.katahdin-online.com/incab.html
PostPosted: Wed Sep 23, 2009 4:12 pm
Thanks guys. Glad you like it.
There's also this (one of the best)
http://www.guitarcollectorshowcase.com/main/?cat=3
and this, for a make your own
http://buildyourguitar.com/resources/bu ... abinet.pdf
cheers
Milton, ON
PostPosted: Wed Sep 23, 2009 5:41 pm
Dave: Your cabinet as well as the guitars are awesome. Do you have humidity control in the cabinet?
Greg
Greg Hatcher
North Carolina
PostPosted: Wed Sep 23, 2009 6:20 pm
Thanks Greg. I don't as yet...thought I'd watch it for a while. I could see some sort of passive inputs down the road (a container of desiccant and/or oversized humidor sponge type thing). It'll never have a forced air unit.
Milton, ON
