It is currently Sun Sep 21, 2025 1:31 pm
 Post subject: Heating Blankets
PostPosted: Tue Nov 24, 2009 12:25 pm
First name: Ken
Last Name: Hageman
City: Statesville
Zip/Postal Code: 28625
Are all side bending heating blankets the same. I have never used one. Have used the lightbulb heat. Trying to get into the 21st century. Any recommendations. What kind of rheostat do people use to control the temperature. What kind of thermometer do you use to check your temperature or do you use one. My universal bending machine is 6 inch wide.
Now that I am 63 years old and heading for semi-retirement, I want to get back into doing some serious building. I have lots of friends and family who can use a guitar.
Thanks in advance for your help.
Ken
 Post subject: Re: Heating Blankets
PostPosted: Tue Nov 24, 2009 12:33 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
They're not all the same. There's various "watts per inch" or something like that. I got my blanket from John Hall (Bluescreek) so I didn't have to worry about getting the right one. I use a router speed control to control temp, and a digital meat thermometer to monitor it.
PostPosted: Tue Nov 24, 2009 12:35 pm
First name: Tom
Last Name: West
City: Williamswood
State: Nova Scotia
Talk to John Hall AT Blues Creek Guitars.
Tom
PostPosted: Tue Nov 24, 2009 12:37 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I use the one John Hall sells and am happy with it. He supplies a router speed controller with it. I rigged up a programmable temperature controller and a timer on mine but that is not a requirment to get good results.
Fred
Fred Tellier
PostPosted: Tue Nov 24, 2009 12:42 pm
John Hall at Blues Creek Guitars has great prices and service. His blankets come with a temp. controller.
I use a cheap oven thermometer from Walmart .
I would suggest that you get a timer- not only can these things turn your expensive wood into charcoal, you can burn your house down..... duh
In Markham,Virginia
PostPosted: Tue Nov 24, 2009 12:51 pm
Correct not all blankets are the same. There are many differnt wattage rating many different types of internal elements some heating blankets can not withstand repeditive cycling but are designed to be always on and a a steady temp. Some are designed to not be flexed. That said stay with blankets sold by luthier suppliers and you will not go wrong.
PostPosted: Tue Nov 24, 2009 12:57 pm
the big difference between the Heat blankets often are watts per inch. 5 watts per inch is perfect for wood bending. This can handle the thermal loading. 2 watts per inch are too weak and while they will eventually get your hot, often you case harden the wood before it is ready to bend.
The 2nd thing is make up of the blanket. Some are a woven material . I found that poured slicone is the best . It withstands rubbing allows flexing without failing. I have worn out 1 blanket in the last 8 years and that was my proto type . The cord failed not the blanket and we have long since moved the cord.
With that being said , not all blankets are the same . Feel free to contact me if you have any question and I will get you the info you need.
PostPosted: Tue Nov 24, 2009 3:20 pm
First name: Christopher
Last Name: Otto
City: Brown Deer
State: WI
Zip/Postal Code: 53223-2920
Just to be precise -- is that watts per square inch?
(Yet another engineer, here. We often get anal about measurement units, sorry about that... )
PostPosted: Tue Nov 24, 2009 3:27 pm
You know I have to look to be sure but I do belive that would be the locical rating as blankets come in various widths and the application is to heat a specific surface area so per sq. inch is the reasonable conclusion.
PostPosted: Tue Nov 24, 2009 4:08 pm
yes blankets are rated in watts per sq in
PostPosted: Tue Nov 24, 2009 5:00 pm
I use one of the 2.5 watt/in^2 blankets from omega.com (6" x 36") and it's worked fine for me so far. I'm a very slow hobbyist, though, so I've only bent 4 or 5 pairs of sides on it in the last few years. I went with the lower wattage because then you can use a regular cheapo dimmer switch from any of your big box stores. It seems to get plenty hot quickly enough. I'm not an expert, though, just stating my experience.
I accidentally ordered mine with the PSA (pressure sensitive adhesive) on one side which I covered with aluminum tape... In hindsight I wish I would have just attached the PSA side straight to one of the steel slats, one less thing to align in the "sandwich."
A timer is a necessity and worth every penny. Even with the timer, I still won't leave the room when the blanket's plugged in.
PostPosted: Tue Nov 24, 2009 8:51 pm
First name: Danny
Last Name: Morales
City: Miami
I got my blanket with the temp control from Bluescreek, It works great. You won't be disappointed!!!
Danny Morales
PostPosted: Wed Nov 25, 2009 11:38 am
I just bought one from John, as well, and bent a set on my old light bulb bender (using the blanket only) and it works well. I watched John's video on bending, which was helpful.
Fred, would you share your enhancements. A programable temp and timer controller would be cool. I want to add some power cord management additions to my rig, as well.
Danny R. Little
PostPosted: Wed Nov 25, 2009 7:06 pm
well, I guess to each his own .. I have the 2.5 per and it works just fine for me (about 100 sets, maybe more, plus binding, cutaway pieces etc), even when bending fast ... which I pretty much do all the time now, no matter what the wood is ... we are only talking about 30 seconds difference max when coming up to temp in order to bend ...
not that I am adverse to using the higher wattage one, but this is what I have had for about 5 years now ... and like was mentioned , the 6 buck dimmers work with this.
