It is currently Mon Aug 04, 2025 8:08 am
PostPosted: Thu Nov 26, 2009 11:35 am
Last Name: Charnock
Country: UK
Hi
I will be joining my fist sides in the next two weeks, my intention was to follow Cumpiano and use a shooting board. I am also considering using a sanding jig with a plate glass base and 80 grit paper stuck to it. I can't recall where I have seen it but it looks a safer option. Any direction on the best way to go would be appreciated.
Regards
PostPosted: Thu Nov 26, 2009 12:00 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
John,
Happy Thanksgiving!
The sanding jig can be found here: http://www.luthiersuppliers.com/products/p11.html
I made one of my own (it was easy) and have used it on a few guitars.
I'm not sure what I think about the jig. The glass and base can flex a bit when you clamp them to a surface (if the surface isn't perfectly flat - so I've chased my tail a bit on some gaps in my joints. There are some tips on the page above on how to adjust for this issue.
I almost wish I had a ground granite slab to either put the sand paper on - or at least mount the sanding jig to.
I don't currently own a shooting board as I don't have the proper plane (YET!) - but I'm heading that way.
Best of luck to you.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Nov 26, 2009 12:15 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
I have the Lee Valley low angle jack plane and built myself a shooting board for jointing the top and back pieces. My biggest complaint with that technique is that the joint is so good that I always have to go to a bright light and even then I can barely identify it among all the grain lines :)
Seriously - I have no experience with a sanding jig, but building a shooting board is really easy, as is jointing the top/back plates with a well tuned and sharpened plane. So I can only recommend it (and I'm really not the most experienced woodworker around...far from it). I can not imagine that you'll get a better joint - especially not with 80 grit sandpaper.
best, Christian
PostPosted: Thu Nov 26, 2009 12:21 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
John,
I am a beginner, and have joined about 8 or so tops/backs so far. i found the shooting board to be easier. I think the key is to get a good sharp plane and set it up. I have an old Record #5 set up to take extremely small shavings. Sometimes I may take a swipe or 2 with my old Stanley #5 first set up to take a bit more off.
Anyway, so far so good and I enjoy the process using the shooting board.
Good luck!
Glenn
PostPosted: Thu Nov 26, 2009 12:55 pm
You could say I use a shooting board, but I don't have a proper board per se. I just put the top or back on a piece of ply. It's the method Hesh posted a few years ago. I'm sure you can find it if you search. The shooting board definitely has it's perks. It's just easier to control things.
PostPosted: Thu Nov 26, 2009 1:08 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
If you have a table saw with a cast iron table you can use that instead of opting for a sanding jig. The saw tables are ground nice and flat and you can use some adhesive backed sandpaper or double sided tape to stick the sandpaper and do it yourself.
Peter
PostPosted: Thu Nov 26, 2009 1:21 pm
I am sooo on the hand plane side of edge jointing but I just wanted to point out that sanding isn't a slam dunk. It has it's nuances and techniques as well as using a plane. As Todd intimated, hand plane skills are very useful, (I would say invaluable ) and if you learn them now you will have a tool and skill that will see you through many a guitar and other woodworking situations. No harm in learning how to sand properly either, I just wouldn't do it on a edge joint. :D
Link
PostPosted: Thu Nov 26, 2009 1:50 pm
Last Name: Charnock
Country: UK
Looks like the plane and shooting board has won the vote !
PostPosted: Thu Nov 26, 2009 4:13 pm
Last Name: Shaw
City: Philadelphia
I think a shooting board is faster then a sanding jig and give a way better edge....Mike
PostPosted: Fri Nov 27, 2009 12:32 am
City: winnipeg
State: manitoba
Country: canada
I guess that I am the odd man out in this discussion but I have had reasonable success with 80 grit glued to a half inch thick piece of glass. the glass is mounted on 3/4" particle board. I find it good for trimming bracing as well.
I stick both sides together with double sided tape and use even force while sanding.
Bob
PostPosted: Fri Nov 27, 2009 4:20 pm
Last Name: Charnock
Country: UK
I suppose another way of shooting the boards would be to tape them together and run them along a bit on a router table with the fence set to take a whisker off.
Is this a viable option ?
PostPosted: Fri Nov 27, 2009 5:59 pm
First name: Matthew
Last Name: Rust
City: Columbus
Zip/Postal Code: 47201
Another vote for the plane/shooting board method. Nobody has talked about how cool a pile of mahogany and spruce ribbons looks on the bench top!
But seriously, it is pretty easy to get a perfect joint as long as the blade is sharpened well.
I am sure both work though.
Don't confront me with my failures--I have not forgotten them.
PostPosted: Sat Nov 28, 2009 2:20 am
Last Name: Charnock
Country: UK
Thanks all
I am going to make up a shooting board this weekend.
What is a good length of shooting board, would there ever be an instance when I would use it to trim sides ?
PostPosted: Sat Nov 28, 2009 7:53 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I joint my plates on a jointer, which is strange for me because I probably use less electricity than most building a guitar. My Dad is a retired building contractor. I was talking about methods to joint plates, and he said. "that's what a jointer is for". If they need touching up a little I use sandpaper on my table saw table. The fence will help keep you at a 90 degree angle. I've also touched them up with adhesive sandpaper on a 24" level. I don't have a plane big enough to use a shooting board. wow7-eyes A perfect joint is what's needed reguardless of how you get there.
PostPosted: Sat Nov 28, 2009 8:09 am
Last Name: Charnock
Country: UK
Hi Todd
You mention a video - should there be a link ?
PostPosted: Sat Nov 28, 2009 9:57 am
segovia wrote:
Hi Todd
See post #5.
I use a shooting board like the one Todd shows how to make. Works great even though I use it with an old Miller's Falls 4 1/2 sized plane. A longer plane would be nice but I get by, just takes a bit of care in the technique.
PostPosted: Sat Nov 28, 2009 10:33 am
Todd: The purpose of the wedges on your shooting board is to produce a slicing cut as opposed to a plowing cut (if you omit the slope and plane your sets paralel to the plane of the plane)? Does this produce a better gluing surface?
Users browsing this forum: meddlingfool and 10 guests
