It is currently Fri Aug 15, 2025 12:38 pm
 Post subject: Removing a decal logo
PostPosted: Thu Feb 04, 2010 3:58 pm
Can anyone out there tell me a good way to remove this counterfeit
decal without damaging the finish if possible. A customer bought this guitar knowing
it wasn't a real Martin and wants to remove the falseness of it.
The sticker inside is coming out too - It's easily peeling up.
PostPosted: Thu Feb 04, 2010 4:20 pm
Dave buddy I use these:
:D Seriously though I have never seen a counterfeit Martin before - might you have more pics to share?
PostPosted: Thu Feb 04, 2010 4:49 pm
If its a water decal (most are) AND its not under any finish, simply soak it off .. if its been sprayed over (thats how I do them) then you have to remove finish to get it off .. if you are lucly there is enough finish left underneath it to polish out and you are good .. otherwise, you will have to spray more on ...
as for the inner label ... scrape it off with a chisel thru the soundhole ...
PostPosted: Thu Feb 04, 2010 6:24 pm
Hesh- Nah, not much to see .It's some kind of import that this stooge tried to pawn
off as a Martin. But the kid who bought it likes it so I'll see if I can fix it up for him.
I may take you up on the Claymore if I have problems with that headstock! :D
Tony-Thanks. Yeah I found out it does have finish over it .
PostPosted: Thu Feb 04, 2010 6:33 pm
First name: René
City: Bossier City
State: Louisiana
A 2-1/2" hole saw thru the back should get out paper decal,just kidding! :lol: Seriously though from what little I can see of the inside it doesn't look to shabby. Do you think this an Asian guitar? I would like to see the rest of it.
René
PostPosted: Thu Feb 04, 2010 6:46 pm
:lol: I like the way you think Rene! :D
PostPosted: Fri Feb 05, 2010 2:36 pm
First name: windell
Last Name: cullers
City: fayetteville
State: ar
Zip/Postal Code: 72701
Naphtha will remove many types of adhesives without harming the label or the glue surface. Lighter fluid is usually safe also. If the label is under the finish you will have to remove the layer over the label.
PostPosted: Fri Feb 05, 2010 3:00 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
What Tony said. Probably finish over it. Not hard to do a small refinish on it though.
Hesh in the 60's had a few of those around on Recon patrols. You could also take apart and use the explosive (C-4) out and use it to cook food or heat water. A piece about size of thumbanail would do it. We always took an extra in monsoon time just for that. Didn't want to do it to all, might need em some nights. Also didn't want to stomp on them. We had a new Lt. we tried sevral times to warn, he didn't listen, nuff said.
