It is currently Thu Aug 14, 2025 7:57 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Feb 06, 2010 9:32 am
Alexandru Marian wrote:
Yes, that's it. I don't have Cumpiano, but on all "famous plans" they are tapered exactly the same as they are tapered at their other end, down to nothing or app. 1mm. Best is no to butt then right on the joint (not your case here, but when doing a regular 2 piece) but to cross one of them over it.
Just to say Flets plans in "Making Master Guitars" by Courtnall actually have those lower braces tucked into the tailblock, no taper at that end. Can't get much stiffer than that! :shock:
Fletas also often used cedar as topwood too apparently
PostPosted: Sat Feb 06, 2010 11:05 am
Country: Romania
That is quite interesting, thanks! I guess Fleta has been experimenting with this. The typical Fleta copy out there seems to be more "normal", here is an example:
Build log
PostPosted: Sat Feb 06, 2010 11:14 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
I measured the thickness of the top, and it's somewhere between .100" and .110"
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Sat Feb 06, 2010 1:12 pm
Philip, you should be in the ballpark with that thickness.
J.S. Bogdanovic book "Classical Guitar Making" suggests 0.090 to 0.095 for stiff cedar.
PostPosted: Sun Feb 07, 2010 3:25 pm
First name: Phillip
Last Name: Patton
City: Yoder
I had to steam the sides twice, because the first time there too much spring back, but they seem to have turned out ok.
Today I glued the kerfing on the first side in preparation for gluing it to the soundboard:
I also glued together the two halves of the back....
and inlayed the backstrip:
And I slotted the fretboard:
Regards,
Phillip Patton
PostPosted: Sun Feb 07, 2010 4:58 pm
Country: Romania
What is the side thickness, they look very thick to me. You don't need more than 2mm for a "normal" design.
Build log
PostPosted: Sun Feb 07, 2010 6:36 pm
First name: Phillip
Last Name: Patton
City: Yoder
I asked the people who processed the wood for me to sand the sides to .080" and they came back slightly over that, but it's pretty close.
Regards,
Phillip Patton
 Post subject: What I did today.
PostPosted: Mon Feb 08, 2010 9:29 pm
First name: Phillip
Last Name: Patton
City: Yoder
Tomorrow I'll brace the back and glue it to the sides. On my first two guitars I made the mistake of bracing the back days or weeks before gluing it to the sides, and they lost all their arch. [headinwall]
Regards,
Phillip Patton
PostPosted: Tue Feb 09, 2010 6:19 am
Looking good Phillip
Nice to follow your progress
PostPosted: Tue Feb 09, 2010 12:20 pm
First name: Phillip
Last Name: Patton
City: Yoder
Gluing on the cross grain strip:
Gluing on braces:
Regards,
Phillip Patton
 Post subject: Got the back on!
PostPosted: Tue Feb 09, 2010 6:23 pm
First name: Phillip
Last Name: Patton
City: Yoder
Regards,
Phillip Patton
PostPosted: Wed Feb 10, 2010 5:42 am
I like your "low tech" approach to the build, and that is not a put down in any way.
You are obviously finding materials and a way to do things by thinking for yourself rather than with a wallet.
I admire that - looking forward to seeing more of your build. (And hearing it?)
PostPosted: Wed Feb 10, 2010 7:13 am
That's looking really nice, looks a little overbraced, but only you, with the wood in hand, can be certain about that. I like the colour scheme with the darker top and maple sides, that will make a pleasing contrast.
Did you feather the centre of the closing braces before gluing on the back? If not, be careful in the future as any brace not tucked and not feathered to nothing, including the centre of the closing braces, can be dislodged easily if knocked. Also, there are many multi-piece tops around that don't have the cleats added to the seams, did you allow for their mass when bracing?
PostPosted: Wed Feb 10, 2010 9:33 am
First name: Phillip
Last Name: Patton
City: Yoder
Don't worry, no offense taken. :) I'm starting out low tech, and adding tools and technology as I go. Poverty is the mother of invention. :D
I'll see about posting a sound clip when I'm done. I've tried to record some with my camera, and it doesn't sound too bad.
Thanks for the input! I didn't know braces could be knocked off like that. No, I didn't feather the closing braces, but I will on the next one.
I used 5 braces on the back instead of 4, because the maple I used for the back was flat sawn, and showed a marked tendency to curl up like a potato chip. :mrgreen: But I did use thinner stock for the braces (1/4" instead of 5/16").
The top is thinner than my first classical, and the braces are a little slimmer, so I think the extra mass is accounted for. We'll see. The tap tone sounds good, but then I'm not sure what to look for. ;)
Regards,
Phillip Patton
PostPosted: Wed Feb 10, 2010 4:06 pm
First name: Phillip
Last Name: Patton
City: Yoder
Routed the binding channels and installed the inlay strip on the end:
Regards,
Phillip Patton
PostPosted: Wed Feb 10, 2010 8:51 pm
First name: Phillip
Last Name: Patton
City: Yoder
Now that the box is closed, I've noticed that this one is much louder than my previous two. That seems like a good thing. Right?
Regards,
Phillip Patton
PostPosted: Thu Feb 11, 2010 5:58 am
I wouldn't complain about it being louder certainly - what woods did you use for previous builds?
PostPosted: Thu Feb 11, 2010 12:04 pm
First name: Phillip
Last Name: Patton
City: Yoder
I used recycled piano soundboards for the tops, and osage orange for the backs and sides.
Regards,
Phillip Patton
 Post subject: Today, binding!
PostPosted: Thu Feb 11, 2010 12:08 pm
First name: Phillip
Last Name: Patton
City: Yoder
So far, binding is my least favorite part of the whole process, but I did learn a few things on my first two projects, so it's going easier on this one.
I bought a Dewalt palm router/laminate trimmer, which so far seems to be more controllable than my full size router.
I'm using walnut for the binding. I cut up a bunch of strips, taped them together, and bent them in my bender. They came out with some kinks, so I have to tweak them on my pipe bender to get them to fit right.
Regards,
Phillip Patton
PostPosted: Thu Feb 11, 2010 6:50 pm
First name: Phillip
Last Name: Patton
City: Yoder
Scraped the binding flush on the back, and glued the bindings on the soundboard side:
Regards,
Phillip Patton
PostPosted: Fri Feb 12, 2010 9:02 am
Can't wait to see it with the tape off the top binding. Tease! pfft
PostPosted: Fri Feb 12, 2010 12:19 pm
First name: Phillip
Last Name: Patton
City: Yoder
Here you go:
The binding came out pretty well. Only a few small gaps. Nothing a little Bondo can't fix.
Just kidding! :mrgreen:
Regards,
Phillip Patton
PostPosted: Fri Feb 12, 2010 2:38 pm
Looking good!
I would suggest filling any small binding gaps with Walnut dust and CA but you probably knew that.
It will be far less obvious than either Maple or Cedar when finally finished and binding width/depth will appear even - guess how I know that. [headinwall]
PostPosted: Fri Feb 12, 2010 5:37 pm
First name: Phillip
Last Name: Patton
City: Yoder
Some shots showing the fit of the neck. It's better than my last one. Just a little "flossing" should make it perfect. [:Y:]
Here's a little tool I made today. It's for pressing frets.
Regards,
Phillip Patton
PostPosted: Sun Feb 14, 2010 11:04 am
First name: Phillip
Last Name: Patton
City: Yoder
Today I flossed the neck/body joint. To see what it was like before, there's pics in a previous post. Here it is now:
I also tapered the neck shaft a little:
Regards,
Phillip Patton
Users browsing this forum: jfrench, Ken Lewis and 17 guests
