It is currently Sat Aug 16, 2025 3:09 am
PostPosted: Tue Feb 16, 2010 12:30 am
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
StewMac used to sell this item - a bridge pin hole saw. It has been discontinued.
Is there another source for these OR - what are you using to cut a slot for the larger strings (at least) your bridges?
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 16, 2010 5:23 am
It's just a jig saw blade set in a handle, you can make these easily yourself with dowel and blades, in varying sizes.
PostPosted: Tue Feb 16, 2010 5:47 am
I use a coping saw blade with one end broken off (so it fits through the hole) and masking tape on the other end for a handle. But you could easily make a wooden handle for more comfort,
Chuck
PostPosted: Tue Feb 16, 2010 7:54 am
...and then there are those who leave the saw blade in their jigsaws and cut the slots a lot faster...
PostPosted: Tue Feb 16, 2010 8:13 am
Last Name: Burner
City: Lincoln
State: Nebraska
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 16, 2010 8:26 am
You laugh .. thats how Mario Proulx does his ...
PostPosted: Tue Feb 16, 2010 8:33 am
Indeed he does...same guy who carves necks with a Lancelot!
BTW, Sylvan Wells also keeps the blades in his jigsaw...that way they don't get lost! laughing6-hehe
PostPosted: Tue Feb 16, 2010 8:38 am
And I have seen that done on Cupiano site also (he pads plate of jigsaw)
They must be braver than I am. :shock: [uncle]
PostPosted: Tue Feb 16, 2010 8:39 am
That's what I do now. Same blade Todd mentioned. Try it on an old bridge clamped in a vise, you'll be surprised at the control you have.
TJK
PostPosted: Tue Feb 16, 2010 8:48 am
Yeah, I find I have better control using the jigsaw than doing it by hand also. I also cut the slots on my slotheads with my Bosch jigsaw.
Joe
PostPosted: Tue Feb 16, 2010 10:08 am
Yep, I use my Bosch jigsaw, works great with the proper blade.
Gwaltney Guitars
PostPosted: Tue Feb 16, 2010 12:38 pm
Anyone use a Dremel instead?
PostPosted: Tue Feb 16, 2010 12:42 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
But I keep losing my jig saw oops_sign oops_sign oops_sign
I use a jig saw also. Like Joe said I have more control with it, than doing it by hand.
PostPosted: Tue Feb 16, 2010 12:51 pm
Last Name: Abercrombie
I use a Dremel and a burr for this job- I like to curve/ramp the slots.
It can be a bit tricky to make sure the slot is centered properly- I may use the jigsaw to establish the cut next time.
PostPosted: Tue Feb 16, 2010 1:24 pm
Last Name: Burner
City: Lincoln
State: Nebraska
I guess for some reason I thought the slot needed to be cut at an angle, similar to the path the string takes. Why I though this I have no clue.
You are cutting these slots in the bridge BEFORE it is glued to the top???
Wow - I laughed earlier and now I'm learning a complete new take on my simple question.
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 16, 2010 1:43 pm
Paul Burner wrote:
I guess for some reason I thought the slot needed to be cut at an angle, similar to the path the string takes. Why I though this I have no clue......
Paul,
A ramp or angle is a good idea. I wouldn't leave it perpendicular.
Paul Burner wrote:
......You are cutting these slots in the bridge BEFORE it is glued to the top???
No, after.
Paul Burner wrote:
.......Wow - I laughed earlier and now I'm learning a complete new take on my simple question.
There are many ways to do any task in guitar building - you knew that already.
The great thing is that there are forums where we can all argue about which way is best. bliss bliss bliss
PostPosted: Tue Feb 16, 2010 3:06 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Todd - how far forward do you make your slot?
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 16, 2010 5:47 pm
Same for me, I found it the same last time - I have the jigsaw blades to fit handle to for next ones.
PostPosted: Tue Feb 16, 2010 6:13 pm
I forgot to add that I use needle files to finish off the job in any case.
PostPosted: Tue Feb 16, 2010 8:45 pm
Two different things. Slotting the bridge and ramping the string slots. I slot the bridge pretty well perpendicular then ramp the string slots individually. My goal is to keep the break angles fairly consistent from string to string, visualizing the the string path through the upper part of the bridge and trying ensure the string makes contact with the bridge along its length.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Tue Feb 16, 2010 9:25 pm
I've been gluing the bridge, Countersinking the pinholes, cutting the pin taper, and then slotting straight with the jigsaw just deep enough to accept the string. Then finish and ramp with the files. I copied Tony Karol's bridge making jigs a couple of years ago and they put the pinholes in line with the saddle slot. That makes the ramping a lot easier as the break angles are more consistent.
PostPosted: Tue Feb 16, 2010 9:57 pm
I grind the end of a Bosch blade so it fits into the handle for exacto blades. Makes for easy blade changes.
PostPosted: Tue Feb 16, 2010 10:05 pm
Jigsaw here too. Very simple, accurate and fast....
PostPosted: Wed Feb 17, 2010 9:36 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
When the power goes off, mine still works. ;)
Basic jig saw blade set into an old foam brush handle.
Hank Mauel
PostPosted: Thu Feb 18, 2010 2:18 pm
That's the time to go drink the beer in the fridge otherwise it will just start getting warm...... LOL
Users browsing this forum: NikolayUsalf and 24 guests
