It is currently Fri Aug 22, 2025 8:44 am
PostPosted: Tue Apr 27, 2010 12:36 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
How does one pore fill for example curly spalted maple? I'm using it for my headpiece rosette and but-strip. It is quite porus. I obviously don't want to change the look of the spalt in any significant way.
CA?
Using Robbie's lacquer and spalted maple end-grain dust?
PostPosted: Tue Apr 27, 2010 1:06 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Seal it with blond shellac or thin lacquer.
Then use med. ca to fill.
Then sand level.
Mike Collins
PostPosted: Tue Apr 27, 2010 1:51 pm
Last Name: Abercrombie
Steve-
If your spalted wood is not 'in the guitar' already, it can make it machine/cut a lot more cleanly if you hit it with thin CA first.
Whether you are applying CA/shellac/lacquer, it will soak it up like a sponge in some areas.
I use spalted wood in rosettes and generally do the CA 'thing' before I cut the ring with the router -much cleaner edges.
PostPosted: Tue Apr 27, 2010 9:16 pm
I don't know about guitars but when I have carved spalted wood I apply thin CA, let it set up and then work with it. I have a friend who used to turn spalted wood and he also put thin CA on it and then used his turning tools on it. However, I don't know how to do it on a guitar as I have not used it on a guitar.
Chuck
