It is currently Tue Apr 28, 2026 10:08 pm
 Post subject: regal neck repair
PostPosted: Sun Jun 20, 2010 3:00 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
hey, i bought this thing with a broken neck years ago, and now i wanna fix and sell it. i have no experience with res-os.
wanted to play one for a while, and see what's inside. regal biscuit bridge steel bod.
boy, these regals are really built well :lol: . i wounder if nationals are the same quality inside, probably not.
neck doesnt line up with the bridge (from the top), different sized screws all over ( guess these'll do!), and glue holding some of the supports in place.
anyway, i wrangled the neck out (pretty easy), and glued the little heal piece on ( clean break), and now, my question is this...
the major break is about 3/4 up from the heal cap, and i can flex the break open. i wanted to break it off cleanly, to get a good glue joint there. kinda stubborn, and all i want to do now is open it up and get enough glue in there. never happen with tight-bond.
so, i was going to flood it with ca, and kicker that, then clamp it. think the ca is strong enough? mahog neck.
 Post subject: Re: regal neck repair
PostPosted: Tue Jun 22, 2010 4:53 am
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
If you break it all the way, clamping can be an issue. I try to open the crack as much as I can then use a clarinet or sax reed (very thin, strong tip) to push the Titebond down into the opening then clamp.
Michael
PostPosted: Wed Jun 23, 2010 9:42 am
First name: alan
City: Santa Rosa
State: ca
thanks, too late though.
used ca, :lol:
thanks for da tip with the reed.
alan
