It is currently Wed Aug 13, 2025 3:31 am
PostPosted: Fri Jun 25, 2010 4:31 am
First name: Yiannis
Last Name: Damigos
Country: Greece
Hello from Greece.
After a year of hard work and much help from this forum i reached this point and wanted to share it.
Also would need some advice for the finishing part.
I have the dvd's "A Master in acoustic guitar" Chris Wynne is using danish oil and afterwards a wax for finishing the guitar.
Is this a good way for finishing my first guitar or is it difficult to get a nice result or should i try shellac?
Any other ideas would be appreceated
Many thanks again for all the help i found in these topics.
http://www.yiannis.com.gr
http://www.luthier.gr
PostPosted: Fri Jun 25, 2010 2:43 pm
First name: Yiannis
Last Name: Damigos
Country: Greece
Any thoughts for finishing? idunno idunno idunno
PostPosted: Fri Jun 25, 2010 6:58 pm
Wax would be a very poor finish with little protection. Shellac would be a much better choice, particularly if you apply it in the French polish way.
PostPosted: Fri Jun 25, 2010 8:08 pm
City: Tucson
State: AZ
Congrats man. Yep it's an exciting time eh?
Wishing you luck on what's to come,
Ian
PostPosted: Sat Jun 26, 2010 11:57 am
First name: Yiannis
Last Name: Damigos
Country: Greece
It sure is an exciting moment Ian!!
Can't wait to put my fingers on her!
Darrel is shellac easy to use, cause i don't want to destroy her after all these endless hours...
Yiannis
PostPosted: Sat Jun 26, 2010 12:12 pm
City: Tucson
State: AZ
^Shellac is very gentle to beginners. If you aren't happy with the job you did, just scrape it off and start over. Takes awhile and it isn't as durable as say poly or lacquer, but you won't ruin a guitar using it, that's for sure. [:Y:]
PostPosted: Sat Jun 26, 2010 12:36 pm
First name: Evan
Last Name: McCartney-Melstad
I'd definitely personally choose French polished shellac over Danish oil and wax. It partially depends how careful you will be with the guitar after it's done, however.
Two good resources:
Michael Dale Payne's writeup: viewtopic.php?f=10117&t=25507
Milburn tutorial: http://www.milburnguitars.com/fpbannerframes.html
Evan McCartney
PostPosted: Sat Jun 26, 2010 1:12 pm
First name: Yiannis
Last Name: Damigos
Country: Greece
Then shellac it is.
Hope will work fine for me.
Many thanks for the links.
Cheers...
Yiannis
cron
