It is currently Fri Aug 08, 2025 7:12 pm
 Post subject: I'm stuck.
PostPosted: Sun Jun 27, 2010 9:49 am
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Never mind. Problem solved.
Ed
 Post subject: Re: I'm stuck.
PostPosted: Sun Jun 27, 2010 9:55 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I'd use a high speed die grinder with a carbide bit to grind the head off.
PostPosted: Sun Jun 27, 2010 9:56 am
Good Morning Ed,
Those screws can be a bugger. Try turning the object the screw is holding up to see if you can unscrew it that way. If that dosen't work, slide a thin prybar in there and strike it a few times with a hammer to break the screw.
PostPosted: Sun Jun 27, 2010 10:02 am
Last Name: Haney
Thanks guys. I got it out.
PostPosted: Sun Jun 27, 2010 10:06 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Howdy fellow Texan!
Ed, those screws should break fairly easily. As was posted before, either prying or a pair of pliers under the head should do the deed.
Steve W
Steve Walden
Aspiring Builder,
Bartlesville, OK
