It is currently Mon Aug 18, 2025 10:12 pm
PostPosted: Mon Jun 28, 2010 3:59 pm
First name: Gerould
Last Name: Wheeler
City: Hanahan
State: SC
Zip/Postal Code: 29410
What is the preferred to you use to inlay a rosette? I'm interested in every thing from chisels to machine power. Just curious as to what people use and like.
PostPosted: Mon Jun 28, 2010 4:18 pm
Gerould,
I don't know if there's a preferred way, but here's how I do it. Some put the whole thing together on a workboard, then route and install it all in one piece.
The jig is shop-made, with a spiral down-cut bit.
Center fill is cut out with a bandsaw to roughly fit the channel.
Channels for the purfling are cut for a snug fit.
PostPosted: Mon Jun 28, 2010 8:53 pm
I tried the last one I did with the 1/64" plywood and it really makes it go easier. Thanks Todd.
PostPosted: Mon Jun 28, 2010 9:17 pm
City: Tucson
State: AZ
Schneider gramil and/or a very sharp small v-shaped gauge. Very quiet. very peaceful.
PostPosted: Tue Jun 29, 2010 1:58 pm
I've got a Stanley #71 router plane that I use to ground out after scribing the lines. A #271 would be even better.
I like to build the rosette in place, rather than plugging in an assembled unit. Somehow the pre-built ones never seem to be quite round or uniform.
PostPosted: Tue Jun 29, 2010 11:19 pm
First name: Jan
Last Name: van Cappelle
City: Doorn (near Utrecht)
State: Utrecht
Country: Netherlands
I love this circlecutter
My router plane
PostPosted: Wed Jun 30, 2010 6:51 am
First name: Patrick
Last Name: Sutch
[quote="Javaca"]I love this circlecutter
Javaca: may I ask where you purchased that circlecutter?
PostPosted: Wed Jun 30, 2010 8:31 am
It pretty much depends on the type of rosette you are doing. But I too have been using the Karol jig to cut my my inlay ring channel.
Ovals are a another new method.
Just a side note. If you are going to make a Karol precision base I'd suggest using something other then UHMW because it really doesn't machine well. Delrin, Polycarbonate and even hardwood I believe would be a better choice.
PostPosted: Wed Jun 30, 2010 11:31 pm
First name: Jan
State: Utrecht
Patrick Sutch wrote:
It was made by my former teacher, the flemish luthier Geert Vermeiren.
He makes only small series of them for his students.
PostPosted: Thu Jul 01, 2010 1:23 pm
Last Name: Charnock
Country: UK
I am partly hijacking this thread as I am about to route my first rosette using the Stewart McDonald jig. I have done a test run on a piece of plywood and it seemd OK but getting the right width was trial and error - is the a recommended procedure for marking out and cutting. For example to I draw around the rosette shape on the top and work to (inside a ) a pencil line ?
PostPosted: Thu Jul 01, 2010 8:12 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Gerould,
I modified a Stewmac/Dremel setup to add digital accuracy. I posted it in a thread a while back HERE. Enjoy.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Fri Jul 02, 2010 2:36 am
Last Name: Charnock
Country: UK
That has given me something to think about, two fixed reference points on the hole cutter would also do the same job in allowing an accurate measurement to be taken.
PostPosted: Fri Jul 02, 2010 3:25 am
Here are the tools that I use. The Stanley 271 that Al mentioned and a circle cutter adapted from a stock tank cutter. The arm and head of the cutter is all laminated from Ebony. I also set it by using a digital caliper between the head and the central boss of the tank cutter - very useful if you want to make very slight adjustments to the channel width.
PostPosted: Fri Jul 02, 2010 5:59 am
My preferred method of inlayng a rosette? Having my daughter do them for me! ;) (next time, I'll tell her to tie her hair back when she uses a rotary tool... :o )
PostPosted: Fri Jul 02, 2010 6:11 am
Last Name: Charnock
Country: UK
I'll show it to my 15 year old if I can get her of MSN
PostPosted: Fri Jul 02, 2010 9:48 am
First name: Gerould
Last Name: Wheeler
City: Hanahan
State: SC
[quote="Arnt Rian"]My preferred method of inlayng a rosette? Having my daughter do them for me! ;) (next time, I'll tell her to tie her hair back when she uses a rotary tool... :o )/quote]
Wow! I think this is the best tool to use too! Unforntunatly mine grew up, got married and moved away.... :(
I have to say it's really nice that your daughter takes such an interest in this field. I can only hope that one day I get to teach my grandchildren if one of them so happens to take an interest.
I have to say that I like everything I have seen so far. I now have many Ideas to work with and keep that train of motivation going.
Wow!!
PostPosted: Sat Jul 03, 2010 11:55 am
I love the stewmac router base and circle cutter for the dremel. Works like a champ, and when using a 1/16" bit, you can sneak up on the proper width for the rosette.
Brad Tucker
PostPosted: Sun Jul 04, 2010 8:26 am
I use this Jasper jig and a PC310-with a range of miniature diameter bits, it will cut most any size-more than advertised. They give you the formulae for "wheel" and "hole" -simple, relatively cheap and nearly fool proofhttp://jaspertools.com/productsdetail.cfm?SKU=673046004006&prod=Model-400%20Circle%20Guide&cat=Circle%20Guide
