It is currently Sun Aug 03, 2025 8:16 am
 Post subject: I steamed my guitar!
PostPosted: Sat Jul 17, 2010 6:39 pm
Today after coming in from mowing the lawn I sat down to play a bit with my newly built guitar. I was, at this point, still a bit hot and sweaty. After about 10 minutes I went to get up and noticed that I had steamed a bit on the back of my guitar. I wiped off the water but noticed that I had, what looked like to me, raised the grain in that spot, and ruined that part of the shellac finish on the back!
This is a walnut back, and everywhere in that area that there was a little black line in the grain, it looked like it had raised up and pushed the shellac up with it.
I sanded it down with 400, then 1200, then went over it with some Meguiar's and fortunately it seems to be back to mostly normal.
My question is, it is normally that easy to ruin a french polish? Did I do something wrong in finishing it that it could get messed up that easily? I never did do the grain raise with alcohol then sand back like what is mentioned in the Millburn tutorial on french polish.. could that be the problem?
 Post subject: Re: I steamed my guitar!
PostPosted: Sat Jul 17, 2010 7:00 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
How many coats did you use?
I am no expert so I defer to the others who know, but I would like to avoid such a scenario in the future if at all possible. My La Patrie has a "custom" polish on the top, backs and sides with a matte finish on the neck. I love that guitar. I'd like to know what exactly that "custom" polish is though. It's very thin, yet it seems durable. Maybe a lacquer?
FP is great for the top because it is so thin, but for a guitar that I will be playing a lot, I'd probably like to go with something a bit more durable. at least on the backs and sides. Not sure how successful mixing and matching finishes is though. It works on my La Patrie but they may both be lacquer for all I know. I just know that I love that guitar.
PostPosted: Sat Jul 17, 2010 7:41 pm
Think of all the old furniture with waterglass rings. Same deal.
PostPosted: Sat Jul 17, 2010 7:55 pm
First name: David
Last Name: LaPlante
heat+moisture+new unhardened finish (can)=problem
PostPosted: Sat Jul 17, 2010 8:58 pm
How long do you think it will take the shellac to harden as much as its going to????
PostPosted: Sun Jul 18, 2010 1:03 am
Filippo Morelli wrote:
Well that or treat the guitar with the respect the finish needs. A bazillion classical guitars are all french polish. It's not an issue of whether one plays them a lot - rather of how one plays them. Being all hot a sweaty, then sticking your body against the guitar is not recommended in any circumstance and especially with a french polish guitar.
The good news is that an FP finish is more easily renewed than any spray on finish.
Filippo
Yes well, lesson learned I guess. Didn't know FP was that wimpy! idunno
PostPosted: Sun Jul 18, 2010 8:09 am
Filippo
Exactly. Think of all the times granny slapped you up the head for not using a coaster...
PostPosted: Sun Jul 18, 2010 2:41 pm
First name: Rob
Last Name: Thompson
If you search, I think there are plans for a giant big-sweaty-dude guitar coaster made from a double layer of 3/4" plywood with green felt laminated on one side and an array of carwashing sponges on the other. You'll need to build a circle cutting jig, however.
Peace,
Sanaka
...imagine there were no hypothetical situations...
Users browsing this forum: Bing [Bot], dofthesea, doncaparker and 10 guests
