It is currently Mon Jul 21, 2025 6:45 am
 Post subject: removing tung oil
PostPosted: Fri Aug 20, 2010 8:11 am
First name: Dwayne
Last Name: Gobright
I am refinishing a bass that some one used hardware store tung oil on. Is it critical to get every bit of it out of wood before I refinish? I am planning on zpoxy pore filling the grain. I have sanded with 320grit and wiped down with Naptha . Any Suggestions?
 Post subject: Re: removing tung oil
PostPosted: Fri Aug 20, 2010 9:44 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
If tung oil was used on bare wood (that is probably the case), I don't think you'll be able to get it out, cause oil is a penetring finish, that go deep in the wood.
But, if i'm not wrong, Z-poxy will easily stick over the oil, and after, the wood will be sealed, and you can put any finish you want. The only thing is... if the oil colored the wood, you'll have to deal with this color.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
