It is currently Sat Aug 23, 2025 4:02 am
 Post subject: Laminated Linings
PostPosted: Fri Sep 03, 2010 2:54 pm
Last Name: Charnock
Country: UK
I am keen to try the laminated linings as shown in the John S Bogdanovich book.
As far as I can make out the laiminated sandwich is bent whilst the glue is still wet, is this correct?
Are there any otehr methods for creating laminated linings ?
J
 Post subject: Re: Laminated Linings
PostPosted: Fri Sep 03, 2010 4:00 pm
I use spruce or basswood. I bend the individual pieces over an iron quickly, to get them sort of to shape. Then I let the lining pieces sit over night or longer in my molds. Then I laminate them with LMI glue and a ton of clamps. Once the linings come out of the mold I cut them in half on my bandsaw so I get two linings per. I then run each lining over a champhering bit to give the lining a pleasant profile.. Shown in the pic is two molds as I make a cuttaway side as well. It is amazing how much these linings stiffen up a side of a guitar over kerfed lining. I wouldn't make a guitar without them...
PostPosted: Fri Sep 03, 2010 4:02 pm
I posted a tutorial on how I make mine. It is not the simplest way but I find it very effective. Here is a link:
viewtopic.php?f=10117&t=21455&hilit=linings
Burton
Brookline, MA.
PostPosted: Fri Sep 03, 2010 4:03 pm
That can be done if you are using very thin laminate strips as he does in the book. My laminate strips are .080, so I bend them just like sides. I use hot hide glue and clamp the assembly in a mold.
