It is currently Sat Sep 20, 2025 11:25 pm
 Post subject: removing bark
PostPosted: Tue Sep 07, 2010 5:02 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I got some 20" diameter butternut last week & have chain sawed it to some manageable sizes & would like to remove the bark. I tried splitting some of it off but it's on there real good. Will it loosen up over some period of time . Do I have to worry about bugs?
MM
Mike McNerney
 Post subject: Re: removing bark
PostPosted: Tue Sep 07, 2010 9:02 am
Yes, remove the bark and seal the ends. It's easier to de-bark when the tree is cut in the winter.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Sep 07, 2010 10:23 am
Good to get the bark off. Prevents bug and rot damage. If it's loose, I use a flat pry bar. If tight, a drawknife.
PostPosted: Tue Sep 07, 2010 12:03 pm
First name: Randolph
Last Name: Morris
Mike, the bark will loosen as the drying process begins to happen. Some of it should even curl off by itself. The rest you can pry off or just wait a little longer until it dries more.
PostPosted: Tue Sep 07, 2010 3:21 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I see this as a bit of experiment. I want to try resawing a small number of side & back material to the .187 to .250 thickness & air dry t for 3 months (well stickered & weighted; and then bring it indoors. I think I heard 4 decades ago that some woods can be stained by improper species stickering? Any comments?
MM
Mike McNerney
PostPosted: Tue Sep 07, 2010 3:39 pm
As far as bark removal, I do just as Howard does when I process birch or maple. I would remove it asap unless you want some spalting or stain. The bugs will get into the sapwood if the wood is outside and remains a bit damp and the bark is still on. As for sticker stain, it can indeed be an issue. Use dry low oil/resin woods, like spruce. Or use some plastics...
Users browsing this forum: No registered users and 59 guests
