It is currently Fri Apr 24, 2026 9:29 am
 Post subject: Sunburst LP Completed!
PostPosted: Sun Oct 03, 2010 2:52 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Got the LP all dialed in over the weekend. It plays and sounds great! This is my first burst. It is a pretty acceptable job, so I am not too embarrassed to take it out in public. The yellows and reds of the burst were first done by hand with Transtint dyes diluted in water. I then shot a couple of coats of Target's clear sanding sealer, EM1000. Followed were the deeper wine colors done by spraying EM1000 tinted with Transtint dyes. On top of that went a couple of coats of EM6000 tinted with vintage amber, and I then shot a dozen and half or coats of clear EM6000. The back was pore filled with red tinted pore o pac and stained with red tinted stain. Pups are a SD Jazz in the neck and Pearly Gates in the bridge. I am still waiting on a backordered truss rod cover, and I have to make the cover plates for the back and install a pickguard. This wasn't much of a build as I purchased a Bulldog kit from someone on the forum. More of a finishing project I guess.
Ken
http://www.casperguitar.com
PostPosted: Sun Oct 03, 2010 3:25 pm
First name: matthew
Last Name: capeless
Awsome!
PostPosted: Sun Oct 03, 2010 3:47 pm
Last Name: Thiessen
City: Lexington Park
The burst looks great, Nice job!
John Thiessen
http://www.iszacguitars.com
PostPosted: Sun Oct 03, 2010 3:54 pm
I think it's impeccable Ken!
Great job! [clap]
Milton, ON
PostPosted: Sun Oct 03, 2010 7:09 pm
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
Ken,
Far from being something to be embarrassed by, that's a spectacular burst and a very nice polish job! You should be nothing but proud of your work.
PostPosted: Sun Oct 03, 2010 9:08 pm
Sweet! Nothing wrong with that 'burst! Love it!
PostPosted: Sun Oct 03, 2010 9:28 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Thanks Gents! I played it more this evening. The action is dialed in just the way I like it, and with the wee bit smaller neck, it is a real joy to play. My wife asked me if I am going to keep it. I likely will. I have a 57 reissue and have always wanted a burst ala '59. This will certainly fill the need!
Ken
PostPosted: Mon Oct 04, 2010 9:55 am
First name: Stuart
Last Name: Gort
Very nice work, Ken. You maintained a very "classic LP" look while adding to it! Good job. Did you attempt to find Seymour Duncans that replicated something Gibson was making....or did you try for a different tone?
Tell us a little about your thoughts when choosing pickups?
StuMusic
PostPosted: Mon Oct 04, 2010 5:26 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Stuart - Yes, I did want to draw a fair amount from the 1959 burst, and I wanted the burst to look more like one did when new, not a new one made to look like a 50 year old guitar. I love the tea bursts and other variations, but that isn't what I wanted in this one. I debated about mimic'g the logo on the '59 headstock and actually got a decal for the Les Paul Model script. I put the script on, shot a coat of lacquer over it and asked myself, "Who am I kidding?" So I took it off. The headstock is fashioned on a Gibson, but has a nice two ply laminate rather than paint, and of course, it has my logo. The truss rod cover will be a replica of a '59, and the pickup switch, jack plate, and pup rings all have the vintage vibe. The knobs are not the bell knobs--another intentional diversion. So I guess it is a personalized version of a Gibson burst. Regarding the pups, I have quite a few electrics, but I have never swapped out pickups. Not sure why. So I can't say that I am that well educated on pickups. What I wanted was something a little clearer and brighter in the neck and something a tad hotter at the bridge than what I have in my 57R. I talked with Paul at Bluefish, local guitar shop owner, did some poking around the web, and decided to go with this combination, and had Paul order them for me. So far I am liking the combination. I'll probably get with my buddies to play sometime in the next few weeks, and I'll try it out with the band.
Filippo - Thanks! I have seen a lot of bursts where it looks like a big tear drop template was held a few inches off the body and the burst sprayed, which I am not a big fan of. I have also seen bursts where the dark colors go too far into the center for my liking. As I approached this one, my goal was to avoid both of those. I also wanted the color transition to be totally imperceptible, that is no visible line. I thought I had it until I took pictures. The pictures do show a bit of a transition line (most visible at the waist) that is very difficult to see in person. As I hadn't done a burst before, I dug out the flamed maple sides from the OLF SJ I cracked a couple of years ago and used those for practice. I used a technique I found on the Fine Woodworking site to lay down the colors by hand. I first applied Transtint Lemon Yellow to the entire top. After this I used Bright Red to get the top the orange color I was looking for while also darkening up the perimeter. I worked the Bright Red in from the perimeter, darkening the outer edges as I worked toward the center. I was very careful to keep the orange around the center from getting too dark. Lastly, I mixed some Bordeaux with the Bright Red and hit the very out edge of the perimeter. Once I was happy with it, I let it dry then shot a couple of coats of Targets EM1000 over the top. I then mixed some Bright Red, Bordeaux, and Black in the EM1000 and sprayed the perimeter. I actually used two color mixes, one being such a dark wine as to almost be black at the very edge, and a bit lighter version just inside that. I tried to keep the lighter side of the spray from extending much beyond 1.5 to 2" from the edge. When it was all sprayed, I thought the top was a little too brightly colored, so I mixed some Honey Amber with some EM6000 and shot two coats over the entire guitar, front and back (I did exclude the headstock laminate as I didn't want to tint the logo). That amber gave me the exact effect I was after! I had a pic of a guitar in The Beauty of The Burst (Page 75 of the book if you have it) that I was trying for. In the end I got close, but the Bordeaux I used gives my burst a bit of a red wine coloration not seen in the burst in the book. It is still a keeper, though!
Ken
PostPosted: Wed Oct 06, 2010 6:58 pm
Last Name: Sydenstricker
City: Oscoda
Beautiful guitar Ken!
John S.
PostPosted: Thu Oct 07, 2010 9:07 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Beautiful!!!!! bliss
PostPosted: Fri Oct 08, 2010 5:15 am
Well done Ken!! [clap] [clap] [clap]
PostPosted: Fri Oct 08, 2010 10:00 am
That is stunning. Nice job.
PostPosted: Fri Oct 08, 2010 5:44 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Awesome guitar!
Can you tell us why you chose to tint the EM1000 instead of the 6000? Also, how many coats of 6000 are on there?
Best,
Trev
http://www.PeakeGuitars.com
PostPosted: Fri Oct 08, 2010 8:24 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Parser wrote:
Awesome guitar!
Best,
Trev
Thanks everyone! Trev, I used the EM1000 because its clear and I can easily see what I have mixed up. Jeff at Target noted how well it works as a color carrier, so I decided to give it a go. It worked very well. I did tint the EM6000 with honey amber. I wasn't so concerned about seeing the color at that point.
I probably have 15 to 18 coats of clear on. Hope to get the pick guard and rear covers on this week.
Ken
PostPosted: Fri Oct 08, 2010 8:54 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Thanks for the insight; I've been doing some bursts just with EM6000 and I've found it really won't carry but so much of the transtint. It works well if you are just doing tinted coats, but not really for trying to do a lot of color at once.
Trev
PostPosted: Sat Oct 09, 2010 2:12 am
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
Well done, and I like the non teardrop look.
How long is that in luthyears?
PostPosted: Sat Oct 09, 2010 3:22 am
Man, that is a GREAT link!
PostPosted: Fri Oct 22, 2010 6:52 pm
First name: daniel
Last Name: laudman
City: Bellmore
State: new york
Zip/Postal Code: 11710
Country: united states
Beautiful job! Congrats! [:Y:]
PostPosted: Sun Oct 24, 2010 9:10 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Thanks Daniel. I finally got my pickguard and back plates installed. Here are a couple more pics:
Ken
cron
