It is currently Fri Apr 24, 2026 10:55 am
 Post subject: Neck Problems
PostPosted: Sun Oct 24, 2010 6:04 pm
First name: Aaron
I am having problems getting a straight cut on my neck. I think I might just be impatient, if this is the case I will need to correct this, but if anyone knows any good tips or trick to use when trying to cut a solid neck blank into an angled neck please let me know.
All of the books I have read don't give me any hints. I don't have a workbench, which is probably my first problem since I don't have a table vise but I am trying to make do without.
 Post subject: Re: Neck Problems
PostPosted: Sun Oct 24, 2010 8:31 pm
First name: Russell
Last Name: LaRoche
What kind of cutting tools do you have? How did you attempt this last cut?
Barron Wesley Guitars
PostPosted: Sun Oct 24, 2010 9:21 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Looks like an attempt at a peghead scarf joint.
Try using a razor knife to cut your lines,
then patienly work to the lines with a rasp, then a sanding block.
Be very careful though.
PostPosted: Mon Oct 25, 2010 3:09 am
How about getting it close with a saw, and then truing it up with a plane?? Stack the short piece on top of the long piece so the angle lines up and go to town. Check frequently with a straight edge.
Rob
