It is currently Sat Jul 26, 2025 5:36 pm
PostPosted: Fri Jan 14, 2011 11:43 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
It's another Menards Special. bliss
Mahogany back and sides, multi-piece WRC top, rosewood fretboard, not yet pictured. Ebony bridge. Ebony binding.
Body shape is small jumbo, or as close as I could get drawing it from pictures.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Jan 14, 2011 12:07 pm
First name: Freeman
Last Name: Keller
Sweet. I'll be interested to see how you like the cedar top. Scale length? How did you brace it and how do you intend to tune it? (I'm a bit of a 12 string junkie)
PostPosted: Fri Jan 14, 2011 12:35 pm
First name: Phillip
Last Name: Patton
City: Yoder
I've used the same cedar on a few other guitars, and have liked the results so far. We'll see how it does with 12 strings on it.
The scale length is 25.5" I used standard X bracing on it, but made the braces about 25% taller and wider than I do for 6 strings.
I'm not sure yet how I'll be tuning it. I'm hoping it will do well with standard as well as lower tunings. We shall see. :)
Regards,
Phillip Patton
PostPosted: Fri Jan 14, 2011 12:54 pm
Looking good Phillip. I'm building an L-00 12 string right now (first 12 string) with a cedar top and am planning to tune it to standard. I may try C# tuning just to see what the Leadbelly fuss is about, but will likely stay at standard as I'm not real good at transposing when playing with others.
I have a 1987 Takamine with cedar top that has always been strung at standard pitch and has never had any issues with action, bridge lifting etc. I realize that it is likely somewhat overbuilt, but it does sound very good.
PostPosted: Fri Jan 14, 2011 1:46 pm
Looks very cool. Like it alot.
A picture of the bracing would be great if you have.
Neil
PostPosted: Fri Jan 14, 2011 4:11 pm
First name: Phillip
Last Name: Patton
City: Yoder
Neil
Sorry, I don't think I took a picture of the inside.
Regards,
Phillip Patton
PostPosted: Fri Jan 14, 2011 4:49 pm
Hi Phil,
I have a Suzuki slothead 12 string with a cedar top that I have had since new in about 1982 and it sounds great and has held up very well. The bridge did lift once but i just glued it back down and it has been fine ever since.
PostPosted: Fri Jan 14, 2011 5:33 pm
First name: Phillip
Last Name: Patton
City: Yoder
Shane Neifer wrote:
Hi Phil,
This one will have a slotted head too. Seems like it would save a lot on weight.
One of these days I'm gonna get some spruce from you. :) Do you sell violin wedges?
Regards,
Phillip Patton
PostPosted: Fri Jan 14, 2011 7:08 pm
That is looking awesome Phil. You will really like the slothead (I do!). I have a few violin wedges here but almsot always have archtop mandolin sets which are great for violins as well except that they are slab cut and sawn already.
PostPosted: Sat Jan 15, 2011 4:22 pm
First name: Phillip
Last Name: Patton
City: Yoder
Are the mandolin sets quartersawn?
Regards,
Phillip Patton
PostPosted: Sat Jan 15, 2011 4:25 pm
First name: Phillip
Last Name: Patton
City: Yoder
Got the neck angle set and the neck/body joint flossed:
Also got the heel cap glued on:
And applied some brushing lacquer:
Regards,
Phillip Patton
PostPosted: Sat Jan 15, 2011 6:51 pm
Yup, they are indeed quartersawn. Most of my processing of these go to Roger Siminoff who has been my longest and best mandolin set customer.
I just glued one up last night with fish glue for a violin I am going to make for my son.
PostPosted: Sat Jan 15, 2011 7:20 pm
First name: Phillip
Last Name: Patton
City: Yoder
Well, then, as soon as I have some disposable $, I'll order a few sets. I want to make a couple violins, and a mandolin or two.
Regards,
Phillip Patton
PostPosted: Sat Jan 15, 2011 7:43 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Looking great Phil!
I really like the proportions of the upper bout.
Interesting that you ran the herringbone the same direction all the way around - I like it!
I can't say as I am familiar with too many slot-head 12-strings - your headstock looks great!
Rob
PostPosted: Sun Jan 16, 2011 2:38 pm
First name: Phillip
Last Name: Patton
City: Yoder
Finished shaping and polishing the headstock:
And then glued on the fingerboard:
Regards,
Phillip Patton
PostPosted: Sun Jan 16, 2011 8:56 pm
First name: Phillip
Last Name: Patton
City: Yoder
Pore filling:
The fingerboard glued on:
Regards,
Phillip Patton
PostPosted: Wed Jan 19, 2011 4:49 pm
First name: Phillip
Last Name: Patton
City: Yoder
Did the bridge today:
Regards,
Phillip Patton
PostPosted: Thu Jan 20, 2011 2:58 pm
First name: Phillip
Last Name: Patton
City: Yoder
Seal coat of shellac on the top:
My hanging jig:
First coat sprayed:
Regards,
Phillip Patton
PostPosted: Sat Jan 22, 2011 8:58 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
That is one really nice guitar you are turning out although I have one concern and that is the design of the bridge. To me the bridge pin holes are a bit too close to the saddle slot and the countersunk edge at the upper base end is almost touching the slot. Would this not put quite a serious break angle on the string?
Bill S.
Dream to be a luthier
PostPosted: Sun Mar 27, 2011 12:32 pm
First name: Phillip
Last Name: Patton
City: Yoder
Well, I actually finished this one several weeks ago, but didn't take pictures until now. I got lazy with the finish and left it satin. I actually like it, though most customers probably are more used to high gloss. But this one's for me to keep. :)
Bill S.
I think you have a good point. It's mostly just a problem with the low E course, but I will be changing the bridge design on the next one.
Regards,
Phillip Patton
PostPosted: Sun Mar 27, 2011 6:06 pm
Looks fantastic Phillip. I'm working on a mahogany/cedar 000 12 string right now, so definitely enjoy seeing similar ventures.
PostPosted: Mon Mar 28, 2011 4:13 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
just curious: what type of tuning gears are those, and how long is the head stock? :P
PostPosted: Tue Mar 29, 2011 8:26 am
First name: Phillip
Last Name: Patton
City: Yoder
These are "Golden Age Restoration" tuners from Stew-Mac. They're a whole lot lighter than regular tuning machines. This whole guitar weighs about 4 pounds.
The headstock is about 8" long, maybe a bit more.
Regards,
Phillip Patton
PostPosted: Tue Oct 08, 2013 3:01 pm
have you the plans? Luigi
PostPosted: Tue Oct 08, 2013 8:40 pm
First name: Phillip
Last Name: Patton
City: Yoder
I didn't work from plans, but plans are available somewhere I'm sure. :)
Regards,
Phillip Patton
