It is currently Sun Aug 03, 2025 3:06 am
PostPosted: Tue Jan 18, 2011 5:46 pm
First name: Wendy
Last Name: W
State: Arizona
How do you hold a classical guitar (with neck attached) vertically to work on an endgraft. Anyone have any interesting jigs or vises. Thanks, Wendy
PostPosted: Tue Jan 18, 2011 6:07 pm
Last Name: Ulman
City: Bellevue
State: Washington
I use cam clamps to hold the guitar against a workbench or setup table with the headstock protected and resting on the floor.
Joe
PostPosted: Tue Jan 18, 2011 6:26 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
build a guitar troji!!!!!!!!!!!!! love that thing , plans in the toot section!!!!!!
MK5acoustics.com
PostPosted: Tue Jan 18, 2011 6:36 pm
First name: Wendy
Last Name: W
State: Arizona
The guitar troji would be nice with some modification to allow for the neck, but I don't have the room for it. Joe, does it not harm the radius in your top to clamp against the bench side, or do you have something between the bench and the guitar top? Wendy
I use knee clamps.
PostPosted: Tue Jan 18, 2011 6:37 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
here is picture of mine!!!
MK5acoustics.com
PostPosted: Tue Jan 18, 2011 7:02 pm
Last Name: Ulman
City: Bellevue
State: Washington
Wendy, no, not if you set the inside half of the clamp to hold the guitar away from the edge. And yes, I also usually place a towel or carpet pad in between the bench and guitar as a precaution.
Joe
PostPosted: Tue Jan 18, 2011 8:13 pm
First name: Wendy
Last Name: W
State: Arizona
Joe[/quote]
Of course, makes perfect sense, I don't know why I didn't think of that. And Filippo, thanks for the picture of a troji that doesn't require floor space.
Wendy
PostPosted: Tue Jan 18, 2011 10:00 pm
One I made in a couple hours. Nothing fancy, but works very well.
PostPosted: Wed Jan 19, 2011 2:03 pm
First name: Wendy
Last Name: W
State: Arizona
Anyone have any idea why I can't view John's photo? There is just an x where the photo should be. idunno
PostPosted: Wed Jan 19, 2011 2:11 pm
That's the rating, and this is a family-friendly site. ;)
Here it is.
John's is a bit fancier than what I use, which is based on the same idea as his. Mine, and that of a good number of others here, I suspect, uses pipe clamps l like his, but only with carpeted plywood squeezers.
PostPosted: Wed Jan 19, 2011 5:03 pm
First name: Kathy
Last Name: Somerville
City: Edmonton
State: Alberta
Zip/Postal Code: T5S 2V8
http://home.comcast.net/~kathymatsushit ... nds10.html
Kathy Matsushita has some very good photos on her web page, at the address above. I copied the way she attached the pipe clamps to her bench and it worked out well.
Kathy Somerville
PostPosted: Wed Jan 19, 2011 5:39 pm
Last Name: Killin
This is great timing. I built this Troji back in October of 2008 and finally have a guitar body to put in it. Any way it works great and looks cool too. This was made using Rod True’s plans. Thanks Rod.
PostPosted: Wed Jan 19, 2011 5:54 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks for all the pics, I made the vice with pipe clamps like Kathy Matsushita's a while back, but my bench is not high enough for the neck to clear the floor. I still like seeing everyone's different methods for holding guitars in different positions.
PostPosted: Wed Jan 19, 2011 5:55 pm
Last Name: Sollod
Here's my Guitar Vise. ...very easy to make...
www.swiftcreekguitars.com
PostPosted: Wed Jan 19, 2011 10:19 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
very useful for getting the neck dead straight for fret dressing without having to adjust the trussrod.
not much use for fitting an end graft, admittedly ...
PostPosted: Thu Jan 20, 2011 1:48 am
Last Name: Shanklin
City: Windsor
State: ON
Filippo
That bench mount troji is pretty slick. [:Y:] I think I will have to borrow that design.
Bob
PostPosted: Tue Sep 06, 2011 2:15 pm
First name: Werner
Last Name: Bessinger
City: Pretoria
State: Gauteng
Zip/Postal Code: 0044
Country: South Africa
Hi folks
Can anyone email me the plans for a guitar troji? I would love to build one this coming weekend!
Regards
Werner Bessinger
PostPosted: Tue Sep 06, 2011 2:42 pm
This is what I use too. With flexible ply for the jaws it works great and you can put pipe flanges on different benches and move it around if needed.
Here's a tutorial
http://wellsguitars.com/Articles/Guitar_Holder.php
PostPosted: Tue Sep 06, 2011 2:49 pm
Werner wrote:
Hi folks
Regards
Werner Bessinger
Here you go Werner.
viewtopic.php?f=10117&t=26915
PostPosted: Tue Sep 06, 2011 6:00 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I just finished a Troji from the download plans, thanks go to Rod True. With the center of the shelf cut out, a guitar could be held neck down in the Troji.
Fred Tellier
PostPosted: Tue Sep 06, 2011 7:57 pm
First name: Jim
Last Name: Kirby
Haans wrote:
I use knee clamps.
Chuckle [:Y:] [:Y:] laughing6-hehe
Jim Kirby
kirby@udel.edu
PostPosted: Tue Sep 06, 2011 9:19 pm
First name: Jim
Last Name: Hansen
This is a handy little bench troji I copied from one I saw in Rick Davis' shop.
Just some plywood scrap for the bottom and ends. 1/4" hardboard on the sides, and lined with cork and green foam from the fabric store.
Jim Hansen
PostPosted: Wed Sep 07, 2011 9:17 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
I modified my binding cradle to have inserts on top of the holders so I can screw on a cap. Then the whole cradle attaches to the side of the bench. The guitar will almost stay put without the caps, but almost is not what any of us are after.
http://shastaguitar.com/
http://www.kalimbakit.com/
