It is currently Sun Sep 14, 2025 8:20 pm
 Post subject: trash can separators...
PostPosted: Fri Feb 18, 2011 5:05 pm
Are they any good?
PostPosted: Fri Feb 18, 2011 6:33 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
OK....I'll bite.
What's a trashcan separator and is it good for what??
PostPosted: Fri Feb 18, 2011 6:55 pm
If you mean for dust collection, I think ther are to get the coarse particles out. I don't think they remove the very fine particles that clog your lungs.
PostPosted: Fri Feb 18, 2011 7:00 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
meddlingfool wrote:
Are they any good?
Yes, they are very good.
PostPosted: Fri Feb 18, 2011 7:04 pm
Last Name: Peck
City: Templeton
Zip/Postal Code: 93465
They work very well to remove the coarse chips. The collector bag will not need to be dumped nearly as often.
If all you produce is fine particles like from sanding it won't help much. But if you use a planer it will be really good.
Lance Peck
PostPosted: Fri Feb 18, 2011 7:17 pm
First name: Jim
Last Name: Kirby
Sometimes mine works really well, and sometimes it does nothing. I'm sure it has all to do with the angle that the internal 90 degree angle is set at relative to the tangent, but I haven't figured out exactly what the right angle is.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Feb 18, 2011 7:47 pm
Thanks all...
PostPosted: Fri Feb 18, 2011 9:08 pm
Last Name: Peck
City: Templeton
When we used one we had to use a hold down strap to tighten the seal of the lid on the can. Once we did that it always worked.
Lance Peck
PostPosted: Fri Feb 18, 2011 10:26 pm
First name: Mark
City: Concord
Check out the DIY Thien Separator:
http://www.cgallery.com/jpthien/cy.htm
Much better results than the off the shelf versions. These can get close to a good cyclone design as far as scrubbing fine dust.
PostPosted: Fri Feb 18, 2011 11:16 pm
There is actually a brand that makes a molded can lid that angles in just like a cyclone. I don't have a pic or the name... how lame. It works great for the heavier particles but not too much for sanding dust. I only break it out when making moldings. So depending on your use, yes they are good and sometimes not so much. pizza
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
Users browsing this forum: dofthesea, James Orr and 75 guests
