It is currently Thu Aug 21, 2025 9:05 am
 Post subject: Tool time!!!
PostPosted: Tue Mar 29, 2011 12:28 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
My next upgrade , real soon , will be a edge belt sander! Not too small and not to big, however choices seem limited. Any one have a model they recommend?
MK5acoustics.com
 Post subject: Re: Tool time!!!
PostPosted: Tue Mar 29, 2011 8:12 pm
http://www.amazon.com/708448-EHVS-80CS- ... B00005NMV5
I have this one, LOVE IT. It can be adjusted flat for sanding the backs of my neckthrough guitars and radiusing fretboards, and I can use the round end for shaping stuff. It has a 6 inch wide 30 inch long platten and can even radius a six string bass neck.
They have an oscillating model which is probably great, but you can't use the end as a shaper then.
Old growth, shmold growth!
PostPosted: Tue Mar 29, 2011 9:13 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I so wish I could score an edge sander. What an awesome, useful tool! Good luck on your hunt. One day someone will make a jointer edge sander combo.
PostPosted: Tue Mar 29, 2011 10:01 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
that one does look awesome....I have been looking at the Grizzly model too...space is an issue , are you running 110 or 220 volts???
MK5acoustics.com
PostPosted: Wed Mar 30, 2011 12:43 am
I run 220
I had 4 breakers added to my circuit matrix a seperate plug for each breaker, in my garage, som each tool is on it's own breaker.
Which Grizzly are you looking at? I had a grizzly edge sander of similar dimension that I was less pleased with as the platform was less sturdy.
PostPosted: Wed Mar 30, 2011 12:55 am
actually I run 120.
I should probably have a 220 breaker installed for my drum sander.
PostPosted: Wed Mar 30, 2011 9:23 am
Filippo Morelli wrote:
I just wish I could score the space for an edge sander.
Filippo
I'd just like to score the space for the stuff I already have! gaah
PostPosted: Wed Mar 30, 2011 9:58 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Space is an issue. Don't remember the grizzly model but one was around 525 and the other 625. I like the vertical and horizontal option . What kind of jig are you using to radius fretboards?
MK5acoustics.com
PostPosted: Wed Mar 30, 2011 12:53 pm
I don't use a jig I do it by hand and check it with radius gauges and straightedges.
It's funny that you ask that, because the main reason I bought the edge sander was because I had also recently purchased the LMI radius sanding jig and was going to use them together to do my radiusing.
The edge sander I bought was this one: http://www.grizzly.com/products/6-x-80- ... nder/G1140
The support table was too flimsy to work with the jig, and I couldn't get even radii, so I simply copied the movement of the jig by hand and after a little practice was able to achieve perfect radii by hand without the jig, now I do any radius, or any compound radius, faster and easier, without having to jig up. I even hired a welder to weld the table in placre, it still didn't have enough support.
I vowed never to buy another tool again without first seeing it in person and making sure it met my requirements, the Jet sander is 100% better. If I still had my radius jig I'm sure it would easily work with the tool.
