It is currently Fri May 08, 2026 9:40 am
PostPosted: Wed Feb 02, 2005 9:13 am
I was just talking to John How about this:
One day I was reaching way in back of my go-bar deck that was on my bench and a new lazy susan bearing that was on my pegboard nearly hit me in the head .... DUH!
So I took the bearing and attached it to the bottom of the go bar deck. Do I need to explain more ... so simple. Gotta love it.
John O
PostPosted: Wed Feb 02, 2005 9:18 am
I need a big Lazy Susan. my go bar deck is fixed to my celing joists and work top
PostPosted: Wed Feb 02, 2005 9:25 am
Thank you JohnO, I'm gonna make me one too. My go-bar deck is just like yours, a top and bottom attached by threaded rod inside 1/2" conduit tubes. I'm gonna look into making some of those cool spring-loaded gobar sticks too.
John How38385.7276273148
PostPosted: Wed Feb 02, 2005 9:52 am
John do you have to chase it around when you are putting in the sticks? Do you have a locking mechanism to keep it from turning? Just curious, I got a laugh thinking of me spinning my deck as I tried to put it together.....
PostPosted: Wed Feb 02, 2005 10:59 am
Here's another variation on the same theme; this technique is so fast and simple, yet it's elegant and effective...
PostPosted: Wed Feb 02, 2005 11:11 am
No, I don't lock the deck from spinning and is not a problem, but I use the spring loaded sticks so there isn't too much radial movement when I set the sticks.
PostPosted: Thu Feb 03, 2005 8:02 am
JH - Where can you get spring-loaded go-bars?
DES - Farwell, MI
PostPosted: Thu Feb 03, 2005 8:58 am
That is a beautiful guitar back what is it? Describe what you are making there... all the details please. Very clean looking work by the way!
PostPosted: Thu Feb 03, 2005 9:12 am
Darin, Ya gotta make'm yourself. A little electrical conduit, a compression spring a dowel and a couple screws.
PostPosted: Thu Feb 03, 2005 10:55 am
Got a pic of one of 'em? and the Exploded view? John, also is that 1/2 inch EMT (electrical metallic tubing?) What keeps the pieces together when not in the deck?
P. S. That's a good looking back, what is it Taz, Koa? I like it John.Dickey38386.7937615741
PostPosted: Thu Feb 03, 2005 11:09 am
Nope, no photo of them taken apart.
It is really simple though, a screw driven through the pipe near one end of a piece of pipe (8" long or so.) Yes it is the electrical pipe. The screw is just there so the spring has something to rest against. Drop in the compression spring, then the dowel.
The thing that holds them from falling apart is also simple .... I just lay them down on top of the go bar deck when I am not using them.
PostPosted: Thu Feb 03, 2005 11:10 am
The back is Brazilian. I took these photos last year, as Larry Breslin created this double-top (Nomex) cedar classical for me. Here are some post-construction photos of the back after the clamping and finishing effort:
You can see many more shots of the entire construction process on my website:
www.trentonscott.com
SonicAgamemnon38402.6882060185
PostPosted: Thu Feb 03, 2005 11:27 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
trent i know you must be disappointed in that guitar so just ship it to me so you don't have to see it anymore. Wow that is a great looking classical and subperb work
PostPosted: Thu Feb 03, 2005 12:06 pm
That's what I thought Brazilian.... scrumptiously beautiful, great finish too. Thanks for sharing.
