It is currently Sat Aug 16, 2025 12:45 am
PostPosted: Mon Apr 04, 2011 3:28 pm
Dear all,
I am wondering what is the best way to secure the pieces when thinknessing with a hand plane?
I don't have a nice wood working bench, so I tried to make a bench dog that has some 2 mm stops at the end.
I actually just glued some dimes on a piece of plywood. But that didn't help securing the board at all, and I can see that it might potentially damage the plane as well. So, it is not good.
Then I tried just clamped one side of the board to the bench, while I planed the other side. Then rotated the board...
This somehow worked better, but it is very troublesome.
I want to ask you whether you have some better ways to secure the boards? any nice jig?
Thank you so much. Really really appreciate your input.
PostPosted: Mon Apr 04, 2011 4:56 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It just seems dangerous to clamp one side of a thin piece of wood to the table, since the shear force might actually cause a crack or worse...
What about gluing sandpapers to the work board so that the friction is sufficient to hold the piece in place?
Typhoon Guitars
PostPosted: Mon Apr 04, 2011 4:59 pm
First name: Brad
Last Name: Radtke
City: South Haven
State: Mi
Zip/Postal Code: 49090
Cam clamps with a caul between the wood and the clamp, as suggested in Cumpiano's book. Worked for me.
PostPosted: Mon Apr 04, 2011 6:38 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
save wear an tear . If your thicknessing stock ,try a scrub plane. , or regrind an old smooth plane to a radius , and start hogging off material quickly, and then switch to a smooth or jack plane for a final pass. You can also make a planing jig with a 2 by 2 ft piece of mdf, glue a 1by 2 under one end, and glue a strip of wood 2mm high by 25mm wide on the top end ,clamp the edge with the 1 by 2 to your table and plane in the direction of the 2 mm stop. For sides make a longer planing jig 32 in, with stops ,as above.
PostPosted: Mon Apr 04, 2011 10:24 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I use scraps of top or back cutoffs,
that are the thickness I'm after.
.115", or whatever, and lock the top in with 4 of those.
They also let you know when you are getting to the thickness you want to get to.
Users browsing this forum: DennisK, Durero and 12 guests
