It is currently Fri May 08, 2026 6:16 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3  Next
 Post subject: Free Drum Sander Plans
PostPosted: Mon Apr 04, 2011 8:35 am
A few weeks ago I poking around again in that Woodworking for Engineers site and I went deep enough to discover that the auther of the site, Matthias Wandel, is here in Ottawa. So I sent him a message inviting him to my place to see how guitars are made and encourage him to make clever guitar making jigs. He's an interesting fellow. Scary smart, "retired" from the high tech industry and now making a very good living off his web site. Anyway, he took an interest in my drum sander since he's had a lot of people asking him to build and put up plans for one. He asked if he could do an article on it which was fine by me. He took pictures and video and from those made up the article and plans which you can find here:
http://woodgears.ca/sander/thickness.html
Hopefully, the plans will be of use to someone.
Cheers,
PostPosted: Mon Apr 04, 2011 9:01 am
thank you for the plans
PostPosted: Mon Apr 04, 2011 10:05 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Nice, Pat.
Thanks for answering my P.M.
Alan
PostPosted: Mon Apr 04, 2011 10:15 am
Last Name: A
Pat,
Thanks for the link and the plans! I have to ask though - with so many dust producing machines in that area you have, as I understand it is not a great idea to have it near the gas water heater ? Isn't there a risk of fire with what you have surrounding the gas flame ? I see dust producing machines and cardboard.
PostPosted: Mon Apr 04, 2011 1:32 pm
John,
I would be the first to agree that working next to a hot water heater and furnace is not the best situation. I do have ventillation to the outside as well as dust collection. As it happens, I am also currently pricing out the cost of a new workshop above my garage.
PostPosted: Mon Apr 04, 2011 1:47 pm
Last Name: A
Yes - I was curious about this more than critical of it - as I plan to build a new shop in a new house as well. I noticed the space I have available to me also has the water heater and furnance. I may have to enclose my workshop to keep the dust to a mininum near the equipment. Only draw back is that I do not have ventilation to the outside.
PostPosted: Mon Apr 04, 2011 10:29 pm
First name: Rusty
Hi Pat,
Thank you for the plan and video, I want to try and build my own soon.
A couple of questions:
Do you find it hard to have a steady and consistant manual feed of the wood and does that affect the thickness at various points on it?
How are the MDF disks fastened to the shaft so they don't slip, epoxy?
PostPosted: Tue Apr 05, 2011 7:44 am
Hi Rusty,
A steady feed is indeed important to get a finish without any indications of a ripple. So the closer I get to final thickness, the more I pay attention to pushing the wood through at an even pace. Even then I am sometimes left with just a shadow of a ripple but this is no big deal, I remove these during later sanding with an orbital sander.
In answer to your second question, I was wondering the same thing myself when I was starting to build the sander. It turns out that disks fit quite tight on the shaft, I really had to pound to get them on, and it didn't take me long to realize that once they were all on and glued to each other, they wouldn't be going anywhere. So nothing was required (other than friction) to keep the disks from moving on the shaft.
PostPosted: Tue Apr 05, 2011 8:22 am
First name: Tom
Last Name: West
State: Nova Scotia
Rusty: Don't want to steal any of Pat's or Matthias's thunder but will give you my take on the sander. I also built a sander a few years back and the basic principals are very similar to Pat's. I used a 3/4" cold rolled steel shaft that I find strong enough to do the job and allows the use of 3/4" aluminum pulleys which are readily available. I used a 3/4" forstner bit to drill the holes in the MDF. The discs pushed on the shaft and were glued as assembled with titebond. To drive the discs I machined the outer face off a 3/4" pulley until it was flat,drilled 4 holes for wood screws and attached to the drum,tightened the set screws into indents drilled into the shaft. It's as solid as a rock. I think having MDF discs is no problem as the drum can so easily be trued without taking the machine apart. The sanding paper I use is about 3" wide and wound on in a spiral fashion and fasten on both ends with large hose clamps. Congrats to Pat and Matthias for making the plans available.
Tom
PostPosted: Tue Apr 05, 2011 12:02 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Thanks for posting this, and providing your plans! I'm going to build one this week.
Is there a good reason to use MDF for the drum, rather than high quality plywood, or even solid hard wood?
Also, where's a good place to get the velcro, and velcro sandpaper?
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Tue Apr 05, 2011 12:42 pm
First name: Rusty
Philip,
Woodmaster Tools has the Velcro sandpaper and the Velcro backer.
PostPosted: Tue Apr 05, 2011 3:55 pm
First name: Phillip
Last Name: Patton
City: Yoder
RustySP wrote:
Philip,
Thank you, sir! I shall order some straightaway. ;)
The sanding drum on this design is wide enough to sand a joined guitar back. Does it actually work well for that? Is the drum rigid enough?
Regards,
Phillip Patton
PostPosted: Tue Apr 05, 2011 7:09 pm
Yes, I do my joined tops and backs on this drum sander. The only issue I have is that it needs to be re-trued periodically (I've done this three times in five years). I don't know why this should be so, but eventually, I can feel the wood I'm pushing through pulse against the turning drum rather than consistent resistance. Matthias suggested it might be due to changes in humidity. To re-true I take off the velcro and re-sand the drum against the table.
PostPosted: Tue Apr 05, 2011 7:15 pm
First name: Phillip
Last Name: Patton
City: Yoder
Cool. I've been having some of my wood sanded down by someone else, and they charge $50 per hour. I figure this sander will pay for itself just in the first 2 or 3 guitars. [:Y:]
I wonder if sealing the drum with shellac would help prevent movement? Would the velcro stick to shellac?
Regards,
Phillip Patton
PostPosted: Tue Apr 05, 2011 8:02 pm
The velcro is very sticky. I'm sure it would adhere to shellac.
PostPosted: Wed Apr 06, 2011 3:05 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Another excellent Monday article on the woodgears site, and that drum sander will assist quite a few people, I am sure.
Matthias Wandel is IMO a 21st century Leonardo da Vinci ...
PostPosted: Wed Apr 06, 2011 7:44 am
Whats the best way to make those MDF discs?
PostPosted: Wed Apr 06, 2011 8:54 am
First name: Phillip
Last Name: Patton
City: Yoder
I don't know what the best way is, but what I did was use template (actually the 5" pulley) to draw the circles on the MDF, then cut them out close to the line with the bandsaw, then sanded to the line with my belt sander. Then I used a compass to find the center, drilled a pilot hole, then used an awl through the pilot hole to mark the others. Then I used a 3/4" forstner bit to drill the shaft hole.
It got pretty tedious, and I ground off part of my left thumbnail at one point, but it took less than 2 hours, and looks pretty good:
http://www.pattonblades.com/4511-10.jpg
Regards,
Phillip Patton
PostPosted: Wed Apr 06, 2011 9:34 am
First name: Tom
Last Name: West
State: Nova Scotia
The discs don't have to be exact as they clean up very nicely when you true the drum with the sanding block. I just laid mine out and bandsawed. Looks a bit rough when you glue up but cleans up quite easy. I did not leave gaps between discs and used titebond glue,disc locked at one end of shaft as explained in earlier post. Also I did not use velcro but rather just wraped the sandpaper on the bare drum.
Tom
PostPosted: Wed Apr 06, 2011 10:18 am
Pat,
Thanks for sharing the information on your drum sander.
Max
Max Bishop
Brighton, Michigan
PostPosted: Wed Apr 06, 2011 10:40 am
Hmm..... looks very familiar!
PostPosted: Fri Apr 08, 2011 9:47 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
Very cool Pat, congratulations. I really like the binding jig though, that looks so light weight and compact. It looks easy enough to figure out, but if you had some info on that, I may get to work on one of those shortly.
Not sure if it would be the best way, but an accurate and quick way to make circles with a band saw or horizontal belt sander is to spin the blank on a pivot. Start with a board, for this project maybe 4" wide, 18" long. Attach a stick to engage the crosscut slot on the saw so the board is close to the blade. Measure from the blade and mark on the board the location of the radius, screw the blank in there. Make a stop for the sled so the blade aligns with the center of the circle. Push the sled and blank into the blade until it rests on the stop, then spin. If one were to be fancy, the screw location would be on an adjustable track, as would be the cross cut bar, then one could go from the bandsaw to the horizontal belt sander with the same jig and make it spiffy.
Delta used to make a circle jig something like this, great simple tool, too bad they discontinued it.
Rob
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Fri Apr 08, 2011 8:31 pm
Rob,
Here is an earlier thread I started on my binding jig:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=19236
As you will see, I can't take original credit for the design. I believe that belongs to Dan Fobert and then Wes McMillan copied it and posted on this forum. It's like a two dimensional Williams jig so it is much simpler/cheaper to build and takes up less space. Yet since the principle upon which it works is the same so it works just as well!
PostPosted: Fri Apr 08, 2011 10:01 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
Pat: Did you use that thickness sander to make that fine looking tennis racket guitar you're playing in your avatar?
:D
PostPosted: Sat Apr 09, 2011 8:31 am
Yep, I started with my old, wood Dunlop Maxply, put it through the thickness sander and out popped a titanium/graphite Head. That sander is a great tool.
The idea behind my avatar was to show a little about myself. My tennis club opens up for the season on April 26th and I've already got a ticket to the Jimmy Buffett concert happening in Toronto on July 16th. In July I become officially semi-retired from my regular job of keeping nuclear reactors safe for Canada. Life is good.
Users browsing this forum: pullshocks and 17 guests
