It is currently Wed Aug 20, 2025 8:53 pm
 Post subject: Can I use?
PostPosted: Wed Jul 06, 2011 10:46 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
Is it safe to use clothes pins for clamping on my kerfing our do I have to by a crap ton of those kerfing clamps?
 Post subject: Re: Can I use?
PostPosted: Wed Jul 06, 2011 11:00 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Wooden clothes pins work great. You will need to chisel away the jaws a bit to fit your linings & wrap an elastic band around the end to increase the clamping pressure.
There are lots of other options too. Spring clips for holding sheaves of paper are available from stationary suppliers. Cheap plastic mini spring clamps are often available in a box of 50... About 50 cents each last I bought some.
Check out some of the build threads. You'll see lots of different clamps being used.
PostPosted: Wed Jul 06, 2011 11:13 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I use un-hot-rodded clothespins,
with tightbond original glue,
and never had a problem.
I do squeeze the kerfed lining very tight with my fingers,
and hold for a bit, and work around the sides that way.
PostPosted: Wed Jul 06, 2011 11:15 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
That is the same thing I do too.
PostPosted: Wed Jul 06, 2011 11:18 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
I gave up using clothespins a while back and switched to Home Depot spring clamps, for no particular reason except I no longer have to replace the rubber bands around the pins when they rot. It really was not much of a problem. When I was at the A.S.I.A. Symposium a few weeks ago, I took the time to take a tour of the Martin factory. I was very surprised to see them still using clothespins for gluing kerfing. They work great.
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Thu Jul 07, 2011 1:38 am
I got me them Ryan clamps, the ones for the normal kerfing. They seem pretty nifty. I guess that's what you're trying to avoid doing, though, isn't it.
laughing6-hehe
Old growth, shmold growth!
PostPosted: Thu Jul 07, 2011 5:35 am
First name: Tom
Last Name: West
State: Nova Scotia
Binder clips obtained from Staples. Foget how many in a box....?? Half a gross ,maybe.....but cheap and they work quite nice. Think Lance may have done a tutorial on using them.
Tom
PostPosted: Thu Jul 07, 2011 6:28 am
I used all of the clamps mentioned short of the Ryan clamps. I Like Pegasus went with the spring clamps . When I used cloths pins I use a rubberband so the edge would be closed . There are so many methods out there and this is a case of using what you like , as long as the job gets done. Martin used a combination of cloths pins and spring clamps for years .
It is all good .
PostPosted: Thu Jul 07, 2011 6:33 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Thanks alot guys y'all rock!! bliss
PostPosted: Thu Jul 07, 2011 6:43 am
IMHO cloth pins may be fine for dreads, but for small guitars with tighter curves the pressure with an additional rubber band is far from being sufficient. Without mentioning cutaways. I like my linings to be gap free, everywhere.
Small spring clamps from HD work well, I modified them slightly by bending one jaw and lining it with 3/8" tubing to protect the linings. 1" spring clamps with cauls (pieces of kerfed lining) are substituted in recalcitrant areas, tiny 1" C-clamps for cutaways.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Jul 07, 2011 7:31 am
First name: Brendan
Last Name: Dwyer
City: tolland
State: CT
Zip/Postal Code: 06084
i use a combo of clothes pins and the orange tipped home depot spring clamps.
i use the spring clamps at the ends and in the waist, anywhere where the kerfing has a tendency to get squirelly due to the radii. and clothes pins everywhere else.
b
brendan 3.0 new and improved, with better interpersonal subroutines
PostPosted: Thu Jul 07, 2011 7:35 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Another question how many am I going to need? Right now
I'm working on a cutaway dread and a non cutaway.
PostPosted: Thu Jul 07, 2011 7:59 am
If I were doing this initially and know what I know now , I would use the spring clamps. They are not overly strong and get to the tighter radii as Laurant stated above. I seldom use the cloths pins anymore and found the spring clamps more practical for getting the joint dead tight
PostPosted: Thu Jul 07, 2011 4:54 pm
Here's my attempt. I got the clamps off the internet, I cut 1/4 surgical tubing in to short pieces and rolled them on.
They have about the same pressure as the clothespin method but they apply it a little more evenly
Users browsing this forum: Ken Lewis and 39 guests
