It is currently Tue Jul 29, 2025 2:25 am
 Post subject: Naptha
PostPosted: Thu Aug 11, 2011 12:28 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
As far as the folks at the big orange store up here are concerned, there's no such thing as naptha. Is there a Canadian equivalent?
Thanks in advance
 Post subject: Re: Naptha
PostPosted: Thu Aug 11, 2011 12:46 pm
Isnt naptha camping fuel - go to Cdn tire ???? What do you need it for, wet sanding .. use mineral spirits instead
PostPosted: Thu Aug 11, 2011 12:59 pm
Last Name: Denvir
City: Baltimore
State: ON
Thanks Tony. Mineral spirit-methyl hydrate?
PostPosted: Thu Aug 11, 2011 1:25 pm
Last Name: G
Hi, Coleman stove/lighting fuel is Naptha - if you look carefully you can find the contents listed as Napthalene. Different than methyl hydrate. Or buy Ronsonol Lighter Fuel,if you can find that.
cheers
PostPosted: Thu Aug 11, 2011 3:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Gosh, I am probably about to espouse an urban ledgend... but is not Colman fuel highly flammable? More than mineral spirits? And, if your application is wet sanding, mineral spirits is the way to go.
Seems I read somewhere its nothing more than highly refined gasoline... (Coleman fuel)
PostPosted: Thu Aug 11, 2011 3:58 pm
Last Name: Denvir
City: Baltimore
State: ON
Actually, I'm looking to wet my top to look for little dings. you know, the ones you never notice until you've got a layer of finish on :-)
PostPosted: Thu Aug 11, 2011 4:03 pm
oh .. in that case lacquer thinner works fine, and flashes off faster than mineral spirits ... methyl hydrate is not mineral spirits BTW ... its denatured alcohol .. that will work as well ....
PostPosted: Thu Aug 11, 2011 4:40 pm
Last Name: Denvir
City: Baltimore
State: ON
Thanks Tony, once these two are done, I'd love to have you take a look at them.
PostPosted: Thu Aug 11, 2011 6:05 pm
Be careful some things leave a bit of a white haze when they dry after wetting a piece of wood. Naphtha does not seem to do that. I thought Coleman fuel was actually white gas, but I could be wrong about that.
PostPosted: Thu Aug 11, 2011 7:04 pm
That's what I thought too.
PostPosted: Thu Aug 11, 2011 8:10 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Unless something has changed in the last 15 years, Coleman fuel is white gas - very flammable!!! Much more explosive than diesel fuel which is as explosive as anything I care to mess with.
Kevin Looker
I'm not a luthier.
PostPosted: Thu Aug 11, 2011 8:54 pm
Last Name: G
Interesting, the fuel which is indeed explosive and poisonous, sold here as Coleman fuel or lighter fluid, is called Naphtha here. Check the title in the link out. A quick wipe removes any waxes but doesn't harm lacquer.
Mineral spirits is different. Methyl hydrate is different, too. But it sounds like you're actually looking for something other than Naphtha to use.
http://www.canadiantire.ca/AST/browse/5 ... ?locale=en
cheers
edit : link is down. Try this one.http://reviews.canadiantire.ca/9045/076 ... eviews.htm
PostPosted: Thu Aug 11, 2011 9:39 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Coleman fuel is white gas,
not naptha.
I've got a gallon of the Coleman fuel.
It one of the most highly explosive liquids, IMO.
DAMHIKT!
Okay, I was a young, stupid camper at one time!
Good thing I never started any forest fires..
PostPosted: Fri Aug 12, 2011 10:05 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Coleman fuel is actually a complex mixture of light hydrocarbons that is distilled from petroleum. Here's a little tidbit from the Material Safety Data Sheet (MSDS) right from Coleman:
    Solvent naphtha (CAS #64742-89-8) 45-50%
    Aliphatic petroleum distillates (CAS #64742-88-7) 45-50%
    Xylene (CAS #1330-20-7) 2%
    Toluene (CAS #108-88-3) 2%
And some info about naphtha can be found here.
So it looks like Naphtha is used in "White gas", but there's plenty of other stuff in there, that are more volatile than plain Naphtha.
EDIT: I just looked at the data sheet for the brand of Naphtha I use. Here's the ratings:
    Health Rating: 1 - Slight
    Flammability Rating: 4 - Extreme (Flammable)
    Reactivity Rating: 0 - None
    Contact Rating: 1 - Slight
    Lab Protective Equip: GOGGLES; LAB COAT; VENT HOOD; PROPER GLOVES; CLASS B EXTINGUISHER
    Storage Color Code: Red (Flammable)
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Fri Aug 12, 2011 11:04 am
First name: Danny
Last Name: Vincent
Steve,
In Canada you can purchase Behlen's naptha from Mohawk. I use it for the same thing as you. I have used white gas in the past. This stuff doesn't evaporate as fast. I personally would chose this over lacquer thinner as the fumes are much easier to take.
PostPosted: Sat Aug 13, 2011 10:12 am
Naphtha (CAS No. 8002-05-9), synonyms: Aliphatic petroleum naphtha, Petroleum naphtha, Rubber solvent, VM&P (Varnish makers and Painters) Naphtha is a low-cut petroleum distallate, and in its crude form is a petroleum feedstock for other processes.
Naphtha is not naphthalene, CAS No. 91-20-3, synonyms Naphthalin, Tar camphor, White tar.
PostPosted: Sat Aug 13, 2011 10:33 am
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
Hey Steve
Another source for Naptha in Canada is Goudey Manufacturing http://www.goudeymfg.com/index.php/other-products/solvents.html
PostPosted: Sat Aug 13, 2011 11:13 am
Last Name: Denvir
City: Baltimore
State: ON
Thanks David. I had a look at their site and also noticed that they have different types of denatured alcohol. I've been using methyl hydrate for my shellac/french polishing, but I'm not sure it's a particularly healthy option. What do you use?
Thanks in advance
BTW, I'm literally around the corner from you, a block south of Gerrard, between Main and Woodbine.
PostPosted: Sat Aug 13, 2011 1:38 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Hey Steve,
I use regular grain alcohol for French Polish, with excellent results. Pricey, but works well.
Used to get the weirdest looks from the guys in the Montana liquor stores, when I'd pop in for a couple of gallons... "Havin' a party? Nope, just for me." I finally had to tell them what I was using it for.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Sat Aug 13, 2011 2:07 pm
Last Name: Denvir
City: Baltimore
State: ON
Hi Mark, that's be my choice too, but we can't get it up her in the great white north. Or at least this part of it.
PostPosted: Sat Aug 13, 2011 4:56 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
I can't get it in Washington either, but fortunately I'm still well connected in Montana... :)
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Sat Aug 13, 2011 5:03 pm
First name: David
Last Name: Wren
State: ON
Hey Steve ... I've used the denatured Ethyl alchohol from Goudey's and it works just fine. Currently I'm using the pure anhydrous 200 proof alcohol from Commercial Alcohols http://comalc.com/uGrades.php
I can't believe you're that close to my shop!?!? You'll have to pop in one day to say hi!
PostPosted: Mon Jul 16, 2012 10:02 am
Try Toluol thats what we have for decent solvent without any residues out West anyhow...
Charlie
PostPosted: Mon Jul 16, 2012 10:25 am
99.99 isopropyl seems to be working for me to make shellac. I'm not fping though...
PostPosted: Mon Jul 16, 2012 10:42 am
Go to your nearest "Home Hardware" store, and get the "odorless paint thinner". It's straight naphtha. No idea why they insist on marketing it that way, but it is what it is. Works fine.
I've been using methyl hydrate(another ingenious re-naming of a simple substance known as methyl alcohol) for nearly 20 years, to wet woods, and for shellac. No health issues I know of... We can't buy grain alcohol at anything better than 40% ABV in Ontario, but if you cross into Quebec, you can get 95%....
Anhydrous alcohol is a waste of money, because as soon as you open it, it will begin taking-in moisture and return to slightly above 95% ABV, anyhow. The driers used to make it anhydrous may have an affect on your finish, too, and it may be different from one batch to the next. Why risk it, and pay more at the same time?
Users browsing this forum: Bing [Bot] and 8 guests
