It is currently Wed May 13, 2026 9:23 pm
 Post subject: white flecks
PostPosted: Wed Sep 14, 2011 1:07 pm
First name: Mitchell
Last Name: Paulson
City: Missoula
State: Montana
Zip/Postal Code: 59803
I've got a beautiful set of Black Limba that I'm working with. I noticed some small white flecks in the darkest parts of the wood. Could this be some kind of mineral deposit? Any suggestions on removal or treatment?
 Post subject: Re: white flecks
PostPosted: Wed Sep 14, 2011 1:52 pm
Perhaps wiping with Aceton can help?
PostPosted: Wed Sep 14, 2011 5:47 pm
Fine tip black sharpie to color them in just before finish is said to work.
PostPosted: Wed Sep 14, 2011 5:55 pm
There are some variations in the composition of these. For example, I recently noticed some white spots in pores on some Indian Laurel when some water splashed onto it. I rubbed it with a wet rag, and the material in the pores came out. As noted by others, sometimes solvents or acid are needed to remove similar deposits. So, maybe try just water before you go so far as to try acid.
PostPosted: Wed Sep 14, 2011 5:57 pm
PS
I used some black marker in conjunction with a lacquer finish, and the "ink" separated into the various component colors and made a bright green sheen.
PostPosted: Thu Sep 15, 2011 10:25 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I guess it depends on the finish. Even "permanent" makers (i.e. Sharpie) are not permanent if the right solvent comes along (acetone). If someone writes on a whiteboard with a Sharpie, you can clean it using normal dry-erase makers!
PostPosted: Thu Sep 15, 2011 2:21 pm
In my instance, there was already lacquer on the wood when I applied the marker. The ink separated as it was absorbed--maybe like chromotography, where the various chemicals separate as they wick through paper.
PostPosted: Thu Sep 15, 2011 4:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
That kind of makes sense. If this was nitro, then the solvents would have softened the layer and lifted the ink. Maybe better luck with a coat of Shellac over the inked wood first.
Users browsing this forum: No registered users and 68 guests
