It is currently Mon Aug 11, 2025 9:10 am
 Post subject: My Simple Router Jig
PostPosted: Wed Sep 14, 2011 7:09 pm
First name: Bruno
Last Name: Piancatelli
Country: Argentina
hello folks. i came out with this router jig and i wanted to show it to you in pictures. its not fancy and does not look so great. but it has very little pieces and moving parts so i guess its worth sharing.
its basically a blank of hardwood (size in mm: 15x80x220) with a slot for the flat iron rod on the underside. screw holes and bit hole matching the ones on the plastic platform.
on the upperside it has a channel for the bolt that emerges from below. and a simple wing nut and two "rings" (probably a better word for it)
here you can see all the pieces. I made threaded holes to the rod, then located the bolts, one with the flat neck for the axis, the other with full "thread" to use with the wing nut. (they are both 1/4 bolts) and gave a touch of welding to secure them.
so here its set on the Bosch gkf-600 (i think the U.S version is called Colt)
the blank was a little narrow but the screws hold just fine.
so its just a matter of positioning the bit into place and then tighten the wing nut, it hold the rod very firmly and steady.
here“s the rosete before unglueing it from the MDF. there are some bit marks on a little section, but that was the jig failure just my mistake when positioning the bit. and thats the part that goes below the fretboard. so no worries there.
and the rossete
so all in all its very simple and handy.
hope its useful for somebody.
cheers!
Bruno
 Post subject: Re: My Simple Router Jig
PostPosted: Wed Sep 14, 2011 8:21 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Thats a very nice jig, Bruno! I've got some UHWM that would be perfect for this. Thanks for sharing with us. [:Y:] [clap] [:Y:]
Alex
PostPosted: Wed Sep 14, 2011 11:07 pm
First name: Bruno
Country: Argentina
Alex
thanks!
im not good with abreviations.. whats an UHWM?
PostPosted: Wed Sep 14, 2011 11:38 pm
First name: Jim
Last Name: Hansen
Think white plastic cutting board material...
Nice jig btw =)
Jim Hansen
PostPosted: Thu Sep 15, 2011 7:40 am
First name: Alex
Last Name: Kleon
City: Whitby
Ultra-high molecular weight polyethylene. It is easily cut and shaped with most wood working tools, and is great for making jigs.
Alex
PostPosted: Thu Sep 15, 2011 6:58 pm
First name: Bruno
Country: Argentina
Alex
thanks.
I havent seen this kind of material on my town. although there is not much to see around here either :)
PostPosted: Thu Sep 15, 2011 9:16 pm
First name: Jim
Last Name: Hansen
If you have a store that sells the plastic cutting boards, then you've probably seen it and didn't realize it. =)
Jim Hansen
PostPosted: Fri Sep 16, 2011 10:06 am
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
Just a quick question regarding those cutting boards... I've been thinking about using old ones for jigs, etc. Has anyone run one through a planer? I have wanted to, but am not sure how it would be on the blades.
Chuck Kish
PostPosted: Fri Sep 16, 2011 12:57 pm
First name: Alex
Last Name: Kleon
City: Whitby
I think I might have about 15 years ago with my old Delta bench top planer. It would be a little messy, and the UHMW generates a lot of static electricity, so the shavings would stick to everything. Treat it like a piece of wood - make sure the piece is long enough, take equal amounts from both sides, and disconnect your dust collector so that you don't foul ducts or hoses.
Alex
