It is currently Sat Aug 16, 2025 11:22 am
PostPosted: Wed Sep 14, 2011 9:50 pm
Last Name: Livermore
State: Minnesota
At this stage in the game, I usually don't run into these kinds of issues that I don't have the answer to but this evening I was finishing up a pyramid bridge and getting ready to glue it to the sound board. For some reason I decided to sand the dickens out of it and just about put a fine finish on it with sand paper alone. As I went up in grits I had to find a lube to keep the paper from clogging so I put a couple drops of lemon oil on it and sanded a way. Man it was shiny. Downright work of art. Until I turned it over and noticed the oil on the bottom of it.
My concern is that the oil will contaminate my attempt at glue up with titebond.
Am I crazy or is this a legitimate concern?
PostPosted: Wed Sep 14, 2011 9:57 pm
I would think that a light sanding would remove the residual oil. Perhaps clean with naptha and then sand.
http://www.booneguitars.com
https://www.facebook.com/pages/Stephen-Boone-guitar-builder/488208541257210
PostPosted: Wed Sep 14, 2011 10:00 pm
Clean it with naptha and sand a fresh surface. Then you should be good to go. Stephen beat me to it. But I would use the naptha first.
Ken Franklin
clumsy yet persistent
PostPosted: Wed Sep 14, 2011 11:02 pm
State: Minnesota
Thanks guys.
I had already drenched it in DA but Naptha is probably even better.
Will do.
PostPosted: Thu Sep 15, 2011 7:17 am
Last Name: Cox
Oil usually doesn't soak all that deep into wood... Usually less than 0.005" unless you use a vacuum to suck the oil into the wood....
I would use a good sharp card scraper to scrape the bottom of the bridge...
I haven't had good luck sanding out oil - it ends up scrubbing the oil deeper into the wood....
PostPosted: Thu Sep 15, 2011 2:24 pm
State: Minnesota
Thanks guys.
Late night.
Panicked.
Duh, sand it off.
BUT! What if I hadn't caught it? Would the lemon oil destroy the glue bond?
PostPosted: Thu Sep 15, 2011 7:45 pm
Dave Livermore wrote:
Thanks guys.
Late night.
Panicked.
Duh, sand it off.
The oil surely would have distroyed the glue bond.
