It is currently Mon Aug 18, 2025 6:11 am
PostPosted: Mon Sep 19, 2011 8:45 am
Last Name: Cox
Hey guys,
Need some suggestions/advice here....
I like the look of a bound fretboard, but I end up spending several hours chipping all the glue back out of the fret slots after gluing on the bindings.... and then several more repairing the chips on the fretboard caused by chipping out all that glue....
I need a way to get far less glue into those narrow slots in the first time... I gotta quit turning 5-minute operations into 5-hour operations...
PostPosted: Mon Sep 19, 2011 8:54 am
Try filling the slots with wax.
PostPosted: Mon Sep 19, 2011 9:10 am
Country: Romania
Or waxed veneer. Most typical veneer fits well in a fret slot.
Build log
PostPosted: Mon Sep 19, 2011 9:18 am
Some folks cut up plastic milk cartons into strips and insert them into the fretslot before gluing on binding. I have not done this, but it apparently keeps glue out of the slot pretty effectively. And the glue does not stick to the plastic so they can be pulled out after the glue cures. You might want to leave the strips extra wide so you have something to grab hold of when extracting them.
First name: Aaron
Last Name: Craig
State: Missouri
Stewmac sells Teflon fret dam sheets. Cheap and effective. But, I just use thin CA sparingly applied with a micro pipette, avoiding the fret slot areas. No problems so far.
Aaron Craig
PostPosted: Mon Sep 19, 2011 9:41 am
Got a compressor? Blow out the fret slots after you've clamped the bindings on. Unless of course you're using tape then that doesn't work so well.
I've also switched to dry taping the bindings on and using CA to glue, none to very little glue gets in the slot.
PostPosted: Mon Sep 19, 2011 9:49 am
I use a hot putty knife, heated with a blowtorch. Just wear your respirator...
PostPosted: Mon Sep 19, 2011 11:14 am
Grind a #11 x-acto blade point flat, then into a mild hook on the cutting edge and clean every slot at the edge of the bindings (it is the right size) while the glue is still wet.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Sep 19, 2011 3:24 pm
First name: Matt
Last Name: Bouchie
City: Manchester
State: New Hampshire
I learned from Alan Carruth to use plastic covers from nut cans or coffee cans cut up into strips. If it's a bit too thick for the fret slots, just use a scraper to thin them a bit until they fit. Leave them a little taller then the fret slots so they are a bit easier to get out. It's worked out quite well for me.
Matt
PostPosted: Tue Sep 20, 2011 8:25 am
First name: Trevor
Last Name: Gore
City: Sydney
Errr....use less glue??
I've used both epoxy and Titebond for this job. Put the right amount on and don't skid the parts over each other. If this seem too hard doing both sides together, do one side at a time using TB. After 10mins you can do the other side and still be well up on the time to clear slots. I clamp using large spring clamps.
http://www.goreguitars.com.au
