It is currently Fri Aug 15, 2025 11:44 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Post subject: Show off your chisels!?
PostPosted: Fri Sep 23, 2011 4:56 pm
First name: Jim
Last Name: Hansen
I've decided that I need to make some upgrades to my Chisels... The set I have holds a decent edge, but the inconsistency in the shape of the chisel makes keeping them sharp a major pain in the behind.
This is what I"m using now. I wish I had seen this review before I made the purchase.
http://www.sawdustandshavings.com/hand_ ... review.asp
I'm looking to piece together individual chisels that better suit my needs (I almost never use two of these chisels).
I'm looking for some opinions. What do you like? and why?
Jim Hansen
PostPosted: Fri Sep 23, 2011 5:28 pm
I have an ancient set of Marples with the blue plastic handles.
PostPosted: Fri Sep 23, 2011 6:01 pm
I have these things. One of them says "Samson" the other I can't read. They're old, I got them off eBay for $20 bucks each. I sharpened them when I got them, and haven't had to sharpen them again since. I've split and carved braces for at least 3 entire guitars with them so far and they'e still super sharp. I've also done lots of other chiseling things for guitar repairs.
Old growth, shmold growth!
PostPosted: Fri Sep 23, 2011 8:09 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
2 cherries
PostPosted: Fri Sep 23, 2011 11:33 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Have those. Don't like them. Poor metal, always sharpening them.
Waiting money for those... (Lie Nielson)
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Sep 24, 2011 10:03 am
I'm sure Todd Stock will be along here any time now....
PostPosted: Sat Sep 24, 2011 12:03 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
These are my shop chisels.
I really like the ones on the left.
As git-wisp says, they really get sharp and stay sharp.
The marples were $22 at Costco, and aren't bad.
PostPosted: Sat Sep 24, 2011 12:23 pm
First name: Jim
Last Name: Hansen
Yea, I posted this in the wrong forum. I petitioned to have it moved.
I'm interested to see what he has to contribute. =)
I was drooling over those LN's hat Ti-Roux linked the other day. I like the shape, and the fact that they are avaialble in O-1 and A-2.
http://www.lie-nielsen.com/catalog.php?sku=O-1-C#
does anyone own one of these that can comment on the quality of the milling? are the sides parallel and back smooth (no milling marks)?
Also, any comments on which steel is more suitable to guitar building (brace carving, inletting braces, cleaning up joints, etc...). The O-1 or A-2? LN makes these available in either version. I would think the O-1, which LN claims is better suited to lower angles, would probably be ideal, but I'm interested in comments. I keep all of my chisels at 25 degrees.
Jim Hansen
PostPosted: Sat Sep 24, 2011 1:55 pm
First name: alan
City: Santa Rosa
State: ca
I don't know about those chisels, Jim.
My favorite for carving braces is the 1/2" Buck.
The 3/4" Stanley, and Bartlett seem to really plow through the wood,
Whereas the Marples don't do as well,
even when equally as sharp.
Weird, huh?
The Buck and Bartlett I scored at a swap for $10 each.
I think the longer ones are more ergonomic for brace carving.
PostPosted: Sat Sep 24, 2011 2:32 pm
First name: Jim
Last Name: Hansen
My primary interest is in being able to maintain an extremely sharp edge at a low angle (preferably without having to hit the strop/stone too often).
For brace shaving I'm looking to get fine/thin shavings at as many angles as possible (working in a go-bar deck), using as little pressure as possible. I tend to pre-shape my braces as much as possible, so I'm not hogging a lot of material off with the chisels (and these two cherries are pretty good at that if I do).
Jim Hansen
PostPosted: Sat Sep 24, 2011 5:47 pm
Cumpiano told me I should get vintage chisels with long handle, sharpened at a shallow angle, I keep mine at 25 degrees, no micro bevel. This allows me to get very fine curls off the brace stock, with very ine control over how much material I move. The metal on these is typically much higher grade than you can get nowadays, without spending a hundred bucks on a chisel. I'm not adverse to doing that if you like, but there's PLENTY of old chisels on Ebay for cheap, that are just as good, just a little uglier. When I'm done with schooling I'm going to upgrade my entire shop. I'm thinking of becoming a mechanical engineer, or going into the health industry.
PostPosted: Sat Sep 24, 2011 7:07 pm
First name: Jim
Last Name: Hansen
Good post !
25 degrees is what I have on mine now, and I use about 28 degree microbevel, mainly because it makes refining the edge a ton easier.
I've thought about shopping for chisels on ebay. I should set up some searches. I guess I've avoided it because I wasn't sure what I was looking for, and I have no way to know the quality/hardness of the metal. I guess if get them cheap enough, it's probably worth the risk to try a few.
Jim Hansen
PostPosted: Sun Sep 25, 2011 1:26 am
My narrower one says "Samson" on it, and the other one says "orvel............e.. Diamond Edge" in a diamond shaped logo, with "DE" in the middle of the diamond, with an arrow going through it. I wish I knew what the heck it was, I'd look for more of them on the Bay. So I think if you got Samson vintage chisels you'd be okay. The long handles allow me to get the shallowest angle for the finest cut. I'm sure some of these guys can reccomend other vintage brands, I hear the Stanley 750's don't hold their edge, but the other Stanley model is super.
PostPosted: Sun Sep 25, 2011 1:33 am
I did some research my chisel is a "Norvell Shapleigh Diamond Edge" chisel.
PostPosted: Sun Sep 25, 2011 1:43 am
First name: Jim
Last Name: Hansen
Thank you!
You need a new "Word of the Day". May I suggest Shapleigh? :p
Jim Hansen
PostPosted: Sun Sep 25, 2011 9:41 am
Show off ;) :D
PostPosted: Sun Sep 25, 2011 10:06 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Old Marples with wood handles
Old Marples Blue Chip with plastic handles
Ashley Iles - one of my favorites)
Footprint with red plastic handle (the beater)
Henry Taylor with skewed blade - another favorite
Japanese with offset blade - another favorite, found at a flea market for $25 :mrgreen:
Kevin Looker
I'm not a luthier.
PostPosted: Sun Sep 25, 2011 10:32 am
First name: Big
Last Name: Jim
I knew Todd was an old chisler ! laughing6-hehe
Not trying to steal thread here but I do have a question .... Looking at the micro chisels on stewmac .... any experience ? ..... any good ? ...... worth the money ?
PostPosted: Sun Sep 25, 2011 10:34 am
First name: Mark
City: Concord
I have an LN set and love them but rarely use them all. If I was allowed a "do over" I would get a few Narex chisels at Lee Valley, Garret Wade or Highland and invest in better Single Malt.
http://www.finewoodworking.com/ToolGuide/ToolGuidePDF.aspx?id=31061
PostPosted: Sun Sep 25, 2011 10:39 am
First name: Danny
Last Name: Vincent
Kevin Looker
Funny, your beater is my most used chisel. I have the same 1" Footprint that I find the most comfortable, it gets used the most and doesn't seem to need sharpening very often.
I see Lee Valley has the newly re introduced Stanley Sweethearts. http://www.leevalley.com/en/wood/page.a ... at=1,41504
Anyone heard any reports. They are priced well.
PostPosted: Sun Sep 25, 2011 11:22 am
First name: Big
Last Name: Jim
Thats a nice looking set of chisels , I wish they were still made usa though . The set for $219.00 doesnt seem out of line .
PostPosted: Sun Sep 25, 2011 11:42 am
First name: duh
Last Name: Padma
Sockets!
Duh older, duh better!
Personal choice ~ any of the Swedish Eskilstuna makers...EA Berg, Jernbolaget, Esteel harder and harder to find.
Plastic handles pfft
The Eskistuna are on the right. The rest are all carving chisels.
Padmas suggestion to the amateur builders, $20 will go a long way at a pawn shop when it comes to buying a few chisels. Try and go for sockets and stay away from the plastic. Put your money into tone wood, not steel.
Now if you took the early retirement buy out package and gotts money to burn well then buy what thou wilt.
blessings
duh Padma
Ps...learn how to properly sharpen the suckers too! You'll be amazed at how a well sharpened cheapo will perform.
PostPosted: Sun Sep 25, 2011 11:47 am
First name: Big
Last Name: Jim
the Padma wrote:
Sockets!
blessings
duh Padma
Padma ..... me come up and dig through your chisel pile and me bring $20.00 tooo !! :D
PostPosted: Sun Sep 25, 2011 12:12 pm
First name: duh
Last Name: Padma
No.
Although you are most welcome to visit "Padmapa House"
PostPosted: Sun Sep 25, 2011 12:52 pm
Last Name: Cox
I had really inconsistent luck with flea market chisels.. Some are amazing... Others turn out to have been jettisoned by someone because they had been ruined by abuse and would no longer take an edge.....
For the OP with the Twin cherries "Special" with unpolished irons.... Those are some high quality chisels.. The "Special" ones were frequently requested by hard core woodworkers - as the "Standard" ones turned out to have over-polished, wavy, rounded backs.... and you couldn't get a real nice, true cut... By no means do you have to hone the backs till all the tool marks are gone... Only just enough to get the back good and flat...
If you are having trouble with them staying sharp, I would revisit your sharpening technique... Sometimes going to a *Slightly* higher angle will give you an edge that stays sharp for a whole lot longer... especially when you are working harder, more abrasive woods....
Next thing... Before you buy.... Decide specifically what you want and buy the *ONE* chisel you need to do the job.... For example - brace carving... Needs a really fine edge, and a very long blade... I have best luck with a moderately wide blade... Because of the super fine edge for cutting shavings in spruce - a high quality Carbon steel long blade "Patternmaker's chisel" does real well here.... For cleaning up binding routs and inlay in hard back and sides woods - you can use one made out of one of the newer high tech tool steels like A2 or D2 - they are more abrasion resistant and hold up longer in very hard, abrasive woods..... but you can't sharpen them at as fine of an angle - like say 30-35* vs 20-25* you would use for spruce/cedar
This is why many builders end up with a big hodge podge of chisels...
Users browsing this forum: NikolayUsalf and 12 guests
