It is currently Sun Aug 03, 2025 12:51 am
PostPosted: Thu Oct 13, 2011 1:43 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Hi all! I just put my modest and new Jet (performax) 10-20 drum sander to test, and to my surprise (not) found that my vacuum cleaner is not up to the task.
I wonder if you guys could suggest me a capable (and not too expensive, if possible) dust extractor to go along with it? i´ve been looking at some (from Jet and axminster.co.uk) and discovered that there are ones suitable for chips and others that are capable of working with fine dust; is the later type preferable ? i ask this because they tend to be on the pricier side.
thanks for looking,
miguel.
PostPosted: Thu Oct 13, 2011 2:18 pm
I use this http://www.axminster.co.uk/axminster-axminster-awede-extractor-prod376272/, works really very well for a 10-20 (and bandsaw/belt sander/table saw), with a fine filter bag http://www.axminster.co.uk/axminster-awede2-fine-filter-bag-prod818492/(5 micron I think) but I also have a fine dust workshop (1 micron) filter nearby.
May best using http://www.axminster.co.uk/axminster-aw ... rod781189/ with it to keep the particle size down for health reasons.
There is a smaller version, but was advised by Axminster that this was marginal for the machine anyway, and any efficiency losses, e.g. long spiral hoses, fine dust filters, general clogging, etc would not help of course.
Axminster Customer Services were very helpful on the phone.
PostPosted: Thu Oct 13, 2011 2:26 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Hi, Miguel,
I notice that the recommended dust collection cfm rating for the 10-20 is 400. I suspect this is the minimum. I do not have experience with a benchtop sander, but with my dual drum sander, I have a 3hp 2280 cfm dust collector, and I find it to be sufficient. My old 2hp 1200 cfm unit was not adequate, for suction reasons as well as for filtering reasons.
If you plan on doing any amount of sanding, it will be worth your time to get a canister filter. The cloth bags clog up, stretch, and need to be replaced from time to time. Try to get a Delta or a General DC, as those are the ones with nylon-reinforced filters. (The nylon reinforcement is there to diminish wear from the integrated paddles that keep the filter clean.)
Are you able to get General International over there? If so, you might consider the 10-005, and the 10-105. Adding "CF" to the end of the model number gives you the canister filter option, for an additional $150-$200 CAD (I don't know pricing on your side of the pond, sorry.)
PostPosted: Thu Oct 13, 2011 2:50 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
Assuming you're using it in an enclosed space, for health reasons you'll need very fine filtration for a sander, preferably sub-micron. Coarse filtration may do more harm to your air quality than no collector at all. Best solution is to blow it outside, if your space can handle the inflow of makeup air.
David Malicky
PostPosted: Thu Oct 13, 2011 3:07 pm
http://www.google.com/products/catalog? ... CHUQ8wIwAQ
I have this dust collector and the performax 16-32.
Old growth, shmold growth!
PostPosted: Thu Oct 13, 2011 3:51 pm
I have a 1hp 400 cfm DC hooked up to my 16-32 and that works just fine. Short hose helps too.
PostPosted: Thu Oct 13, 2011 4:30 pm
Sanders make a lot of fine dust that quickly clogs filters. Before getting a new collector, you might want to try adding a Dust Deputy cyclone to your current vac. It will separate out the vast majority of the particles before they reach the filter. If your vac still won't cut it, the cyclone will still help if you upgrade to a bigger shop-vac.
http://www.oneida-air.com/category.asp?Id={CC6B6F2A-E3D7-4F18-A53C-B5C357DFE131}
http://www.chassonguitars.com
PostPosted: Thu Oct 13, 2011 4:32 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Thanks guys! Much valuable info, this place really is a precious resource.
Could you explain me this one, David, if you have the time?
cheers,
miguel.
PostPosted: Thu Oct 13, 2011 5:34 pm
First name: David
Last Name: Malicky
The dust that is most harmful to breathe is under 10 microns and invisible (the smaller it is, the deeper it goes into the lungs, and the harder for the lungs to remove). If the filter doesn't trap down to 0.5 micron, the "dust collector" just pumps that fine dust back into the air every time it is turned on--whether the sander is making new dust or not. Lots of good info:
http://billpentz.com/woodworking/cyclon ... lterBasics
David Malicky
PostPosted: Thu Oct 13, 2011 6:28 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
ok, makes sense. thanks for the link too!
PostPosted: Thu Oct 13, 2011 10:06 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I use a harbor freight dust collector, picked it up for 150 or so , I plan on getting the wynns enviromental filter cartridge soon , but it works great..
sorry the place is a little messy ,
MK5acoustics.com
PostPosted: Thu Oct 13, 2011 10:08 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
I tried using a craftsman shop vac , but it got clogged very quickly , not to mention not enough cfm for the sander, having a dust collector seems to keep the sander cleaner and my guess is that the drum runs a little cooler as well..
MK5acoustics.com
PostPosted: Fri Oct 14, 2011 5:20 am
First name: Miguel
Last Name: Bernardo
Country: portugal
OK, been thinking about those small 0.5 microns dust particles and i wonder - again - if it´s more sensible to buy a dust/chip extractor like the one Collin has (http://www.axminster.co.uk/axminster-ax ... rod376272/ - or similar) or to sacrifice the HP and go with a finer filtering capability (eg: http://www.axminster.co.uk/numatic-numa ... rod782719/ ), as for my budget it seems i won´t be able to get the "best of both worlds". i don´t intend to give the drum sander an heavy use, BTW, but some rosewood will go through it.
thanks again,
miguel.
PostPosted: Fri Oct 14, 2011 6:33 am
The numatic is rated at 150 m3/hr, I make that 88 cfm, recommended is 400 cfm for the 10-20, bit on the low side.
Airflow not only sucks away the dust from the machine, but helps removes the dust from the paper (slowing down loading it up) and cools the drum minimising distortion.
If you are only using for 10-20, and will be close to the machine there is:-
http://www.axminster.co.uk/axminster-axminster-awede2-extractor-waste-sack-and-quick-fit-strap--package-deal-prod861353/ with http://www.axminster.co.uk/axminster-awede2-filter-cartridge-prod781186/ for about £230 + delivery in you case(?) but again you would be best to contact customer services for micron rating and performance drop when fitted as it is not on the website.
As I remember for my set-up the told me the fine filter would reduce performance by 50%, giving 500 cfm with this set-up.
PostPosted: Fri Oct 14, 2011 6:50 am
First name: Jim
Last Name: Kirby
Wes,
I have the same collector you do. Could you provide a link to the Wynns cartridge?
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Fri Oct 14, 2011 11:47 am
http://www.wynnenv.com/35A_series_cartridge_kit.htm
Same setup I use with my HF collector. Simple installation and works great.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Fri Oct 14, 2011 11:24 pm
City: Medford
State: Oregon
I use this dust collector with my Jet 16-32 and it works great http://www.woodstore.net/cycduscol.html . I can't detect any dust coming from either the dust collector or the sander.
PostPosted: Sat Oct 15, 2011 7:38 am
Last Name: Cox
I agree - a garden variety shop vacuum just doesn't have enough oomph to really remove the dust from a drum sander....
After using a vacuum cleaner equipped drum sander at a local woodworker's club - I decided to go ahead and buy a proper small shop size dust collector.. I am very happy that I did.
When you start looking at the dust collector offerings out there - take a close look at the specs and efficiency... I found that the cheap Chinese models came with filtration that just isn't up to the task when working with woods that can possibly irritate allergies.... and the proper filter cost added quite a bit to the "Cheap" unit... Then - the CFM rating for the same size motor/amp rating was considerably lower as well... The prices were about the same when you were comparing apples to apples CFM and filter ratings... except the "Cheap" model was about 2x as big and had a huge motor on it....
Spend some time researching your purchase - you won't be sorry you did.... especially in a small shop.
PostPosted: Sat Oct 15, 2011 4:49 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thanks everybody! due to the practical and logistical side of the equation, i think i might go with Collin´s suggestion.
cheers,
miguel.
PostPosted: Sat Oct 15, 2011 10:06 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I just got a delta drum sander with rolling dust remover that works fine. Problem is it keeps tripping my breakers so I can't use them both simultaneously! Dang.
Users browsing this forum: meddlingfool and 34 guests
