It is currently Fri Aug 22, 2025 1:12 pm
PostPosted: Tue Dec 27, 2011 12:54 am
I'm using Bloodwood on the headplates, bindings and bridge on my next project. The bridge blank grain orientation is like \\\\ so I"m thinking of using the same plank to make my bridge plate. Should I be leaning towards a different species from the bridge? Clinton
PostPosted: Tue Dec 27, 2011 6:49 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Bloodwood is really heavy. Could be ok for a bridge, but I would be hesitant to use it as a bridge plate...
What's the density of your plank?
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Tue Dec 27, 2011 1:21 pm
Have you thought about using it for the fretboard as well? Just to keep the same look going throughout the guitar?
Ken Mitchell
Durham, NC
PostPosted: Tue Dec 27, 2011 5:19 pm
I read somewhere that Bloodwood doesn't hold frets well. I have no experience with bloodwood other than binding with it. Clinton
PostPosted: Tue Dec 27, 2011 7:06 pm
Bloodwood's fine for frets. I haven't had any problem with it.
Old growth, shmold growth!
PostPosted: Tue Dec 27, 2011 7:17 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Try it. Might make it bigger and thinner than nomal to lighten it up. I have used blackwood.
I used some heavier pieces of wood for that brace. However, I don't use a bridgeplate that would probably be considered good or proper. But it works very, very well and look at it as a brace in the total build. I was skeptical about making a big plate, but when seen the sucess of the sound from the Boss and guitars I have used it on, my thinking changed.
I have no idea of what bloodwood does or doesn't do as I have only used it as a very thin purf line in binding.
PostPosted: Tue Dec 27, 2011 8:08 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I've noticed that bloodwood does split rather easily... could cause problems holding fret... maybe not as initial fretting but for refrets it could be a bigger problem.
Typhoon Guitars
