It is currently Thu Aug 21, 2025 6:17 pm
 Post subject: RH problem
PostPosted: Fri Dec 30, 2011 9:54 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hi everyone!
As you know, the air is pretty dry in montreal houses during the winter. Yesterday it was -25 outside, so the heating was at his max, and it drops the RH dramatically. I have a humidifier that works pretty well, but it don't have a very big reservoir, so I have to fill it up really often. This is not a problem when I'm home, but If I leave for too long, and if it's really dry, It comes empty and then the RH drop under 40, even under 35.
I was first keeping the RH at 50, but I dropped it to 45 to diminish the problem, but still... So, my question is, should I keep it down to 40%, wich is dry but, at lease it would remain more constant?
...and during the summer, it's just the opposite idunno
Thanks!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: RH problem
PostPosted: Fri Dec 30, 2011 10:15 am
Hi Francis .. for building, I like it best at 38-42%, so if I were you I would drop it another 5%, and if your room still has trouble staying there, get another humidifier.
PostPosted: Fri Dec 30, 2011 10:37 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Thanks a lot Tony! I'll drop it to 40, and it probably OK to keep it stable, the humidifier itself works pretty well.
Thanks again
Francis
PostPosted: Fri Dec 30, 2011 8:41 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I am from mtl. The humidity can be from 40-50%. Same problem here in KC 30-35% rh
PostPosted: Fri Dec 30, 2011 10:15 pm
City: winnipeg
State: manitoba
Country: canada
One way to ease the load on your humidifier would be to hang poly sheet around your working area to limit the area that your humidifier has to control. I did this to control sanding dust (wives don't like sanding dust.) and found that it helped control humidity as a bonus.
A quick and cheap solution.
Bob :ugeek:
PostPosted: Sat Dec 31, 2011 9:39 am
First name: David
Last Name: Lush
City: Louisville
State: Kentucky
Is there any way to add a home made auxillary tank to the existing tank? Not knowing the design of your humidifier its hard to speculate. But if it was similar to mine(which has a plastic tank on each side of the humidifier, easy to access) you could find some sort of spicket from the local hardware store that seals a hole in the plastic tank on both sides with a rubber grommet. A little bit of rubber hose, a 5 gallon bucket, and anouther spicket and you have added anouther 5 gallons to the run time of your humidifier. Crude but cheaper then buying anouther humidifier if you find its neccesary.
David
