It is currently Fri Aug 15, 2025 5:10 pm
 Post subject: Mohawk finishes
PostPosted: Sat Jan 07, 2012 1:31 pm
Last Name: Jager
State: Iowa
Zip/Postal Code: 52553
Am going to finish next guitar with Mohawk Classic Instrument Laquor and wondered if anyone has any experience with it and what finish schedule they used. I am planning on pore filling with z poxy and then go with Mohawk e-z vinyl sealer for one or possibly two coats and then to the laquor for about 5 coats. Anyone see any problems with that?
Thanks in advance for any info you can provide.
 Post subject: Re: Mohawk finishes
PostPosted: Sat Jan 07, 2012 3:18 pm
I use Mohawk CIL. I really like it.
Your schedule sounds good but you're not putting near enough lacquer on. It will shrink back a fair amount (like 50-60%) and 5 coats won't leave you enough for level sanding.
Here's what I do.
2 coats seal with shellac
pore fill (I use CA), sand back to wood carefully.
2 coats seal with shellac,
4 coats lacquer, cure overnight
light level sand with P600 grit wet just to knock down the high spots.
4 coats lacquer, cure 2-3 days
Drop fill any voids along purfling, binding, rosette, cure 2-3 days
Level sand with P600 grit wet being a bit more aggressive getting the surface level about 90% level.
4 light coats lacquer, cure 3-4 weeks
level sand P800, P1000, P1500, P2000, buff menzerna med, fine hand polish with Meguiar's mirror glaze swirl remover.
Stand back and fix my hair in the mirror shine.
PostPosted: Sat Jan 07, 2012 3:52 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Your schedule is about what I use for my ukes but I can't get away with 5 coats. It usually takes me about 10
http://goatrockukulele.com
PostPosted: Sat Jan 07, 2012 7:38 pm
you will have a better result with the vinyl sealer. I use this product and do like it.
PostPosted: Sat Jan 07, 2012 8:00 pm
First name: Stuart
Last Name: Gort
Hey J,
That's an excellent schedule....z-poxy...vinyl sealer...lacquer. Do a thorough job on the pore fill and when you think you have it...apply a 50/50 washcoat of z-poxy/denatured alcohol. Do that and you'll need only one coat of vinyl sealer. There are guys who say vinyl sealer isn't even necessay with a z-poxy washcoat but the factory acted a little funny about that when we talked.
Make sure you use Mohawk's vinyl sealer with their lacquer...I had a conversation with Phillip (Phd chemist) at Mohawk who suggested that the chemical bond will be molecular if these directions are followed.
Mohawk classic instrument lacquer is the exact same product as Behlen...fyi. Made by the same factory.
Also, proper retarder, reducer, and lacquer ratios must be followed when shooting from a gun or a number of problems can follow. Spraying the lacquer with no retarder can result in a skinning of the film prior to releasing microbubbles. Too much retarder will seriously inhibit the hardening of the finish and delay final leveling and polishing. Here are the ratios that I use and give me the most latitude. A premixture of 5% retarder/95% reducer is mixed into the lacquer at a ratio of 1 parts per 4 parts. If there's any question about this make sure you understand. Also....the factory is MOST helpful and will hold your hand through the whole process if you call. Mind you, when buying aerosol cans the reducer and retarder ratios are established by the factory to be optimal for the pressure of the can, the orifice size....ect. In many respect using aerosol cans is simpler. I needed to use a gun and figure all this out but I used their aerosol cans to do my first guitar and it turned out very nicely for a first timer with nitro. Not sure where you're at as a builder.
I spray 8 coats of nitro. 4 coats the first day, knock down the nubs and 4 more coats the second day. No serious sanding between....just nubs. Splitting the layers into two sessions allows a LOT of gas to blow off overnight, which profoundly reduces the amount of time required before leveling and buffing. This advice, provided from Phillip at Mohawk, made a pretty big difference in my experience.
StuMusic
Users browsing this forum: nashrb and 10 guests
