It is currently Mon Jul 28, 2025 5:20 am
 Post subject: Acoustic Bridge sitting
PostPosted: Mon Jan 09, 2012 2:03 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hai, Merry Christmas and A Happy New Year....
I need to know:
How the Acoustic Bridge sit on the soundboard, Just Gluing (hide glue or CA glue?) or
need bolted?
I did bridge repair (nylon) and gluing with hide glue but not strong enough for string tension, so I glued again with CA...
[uncle] herry duh
PostPosted: Mon Jan 09, 2012 3:05 am
City: chicagoland
State: illinois
if the surfaces are mated perfectly, and properly prepared(bare wood), just hide glue should hold the bridge in place. but often screws(bolts) are used on cheaper guitars. screws/bolts are not ideal because they add a lot of extra weight...
PostPosted: Mon Jan 09, 2012 9:00 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank's Nyazzip... bliss the bridge should glue after soundboard finishing or before finishing? [uncle]
PostPosted: Mon Jan 09, 2012 9:51 am
Last Name: Kincheloe
Traditionally, the bridge is glued first on classicals, and finish first on steel strings. Mainly due to the finishing methods used (French polish versus sprayed finishes). I French polish steel strings too, but still finish first because I like to use fancy bridge shapes that wouldn't be possible to polish around perfectly.
PostPosted: Mon Jan 09, 2012 10:31 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
You can put the bridge on either before or after finish. I place it, then tape off the bridge position and then finish. Take the tape off the area of where the bridge will be, and glue it on. I do use vacuum press for clamping the bridge.
Now as to adhesive. After sanding the radius , you can do whatever you want as adhesive. I am not sure about CA. I haven't used it or paid any attention to post on those that do. I have used LMI stuff, Titebond and Gorilla wood glue and never have had a problem with any of them, whether it be braces, binding (I use CA for this a bunch) top and backs or bridges. I am sure by most HHG would be considered the best, I just never use it, and so far no need to. That includes two higher end shops I have worked in. Not to say I won't try it sometime, just not interested in messing with it now.
PostPosted: Wed Jan 11, 2012 12:50 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
ahemm,... bliss thank's, I understand now... pizza thank's Stan...
PostPosted: Wed Jan 11, 2012 12:52 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
thank's alot DennisK, :D
Users browsing this forum: Michaeldc and 15 guests
