It is currently Sun Aug 17, 2025 1:40 pm
PostPosted: Sun Jan 15, 2012 2:21 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I've been using standard straight cutting bits,
that do an okay job,
but I was wanting to improve my rosette channels.
Anybody tried the LMI up/down 1/4" cut bit?
They're expensive, $46.
What are you using?
PostPosted: Sun Jan 15, 2012 2:26 pm
The spiral bits are much better at keeping the chipout down. Here is a Freud down cut spiral 1/4" for $15.
http://www.google.com/products/catalog? ... CHUQ8wIwAA
PostPosted: Sun Jan 15, 2012 2:28 pm
As a machinist it is about SHARP. up or down cut , if you have a dull bit you are not going to have a good result. My issue with down cuts on uncleared cuts , is the chip goes into the work and this creates heat. It also folds wood fibers into the cut and can give a false read on fit.
here is an affordable supplier of solid carbide end mills. I use a 3/32 PN 2F093.
http://www.bqtool.com/shop/index.php?cPath=22
You will see at this price you can afford to replace these as soon as they are dull giving you best results.
PostPosted: Sun Jan 15, 2012 3:03 pm
First name: alan
City: Santa Rosa
State: ca
Thanks!
PostPosted: Sun Jan 15, 2012 4:02 pm
First name: Tom
Last Name: West
State: Nova Scotia
Also a machinist here also and I agree with John Hall on the SHARP factor but don't think there is much to worry about in heat build up when you are cutting a rosette channel.So I vote for a SHARP down spiral or straight bit. A bit of shellac on the area before starting and a slow feed should get you a nice clean edge.
Tom
PostPosted: Sun Jan 15, 2012 4:14 pm
Whats a Wells cutter ??? beehive
PostPosted: Sun Jan 15, 2012 4:36 pm
I think he's talking about a Karol cutter. :)
PostPosted: Sun Jan 15, 2012 4:52 pm
Should have always been called a Karol circle jig as far as I'm concerned.
Anyway, speed of the bit has something to do with how clean the cut is too yes? That's probably also why John Hall uses a mini die grinder, spins at what 5 million RPM ;)
PostPosted: Sun Jan 15, 2012 5:10 pm
First name: alan
City: Santa Rosa
State: ca
Sorry Tony!
Are you the Karol part of that?
If so,thank you!
PostPosted: Sun Jan 15, 2012 6:48 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
It's a Karol cutter in Canada, but it's a Well's cutter in the US wow7-eyes wow7-eyes wow7-eyes
Just kidding, you da man Tony :P :P
PostPosted: Mon Jan 16, 2012 8:18 am
Yes I am Alan .... Sylvan picked up on my design and put up a toot on how to make one, as he thought it was a good design .. everyone used that toot to make one way back when, without ever reading the part about how mine inspired him to do it in the first place. He certainly hepled get it out to the luthing masses ... Its a cool feeing to know that I contributed something useful to help ease what can be a daunting part of the build for some, and get pro results first time out.
PostPosted: Mon Jan 16, 2012 10:04 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I picked up a set of these from Ebay and use them with great results. I think the seller is a member of this forum
http://www.ebay.ca/itm/Luthiers-5-pc-In ... 27c23d841f
Fred
Fred Tellier
PostPosted: Mon Jan 16, 2012 11:24 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Fred, did you get a better price on the shipping? The $32 to Canada in the listing is pretty high.
Alex
PostPosted: Mon Jan 16, 2012 12:55 pm
First name: Fred
Last Name: Tellier
City: Windsor
I can't remember but I might have sent them to a buddy's place in US.
Send him an email, they will go in an envelope so should not be any where near that amount, though we Canadians are often gouged by ebay sellers.
Fred
Fred Tellier
PostPosted: Thu Jan 19, 2012 10:31 am
Last Name: O'Melia
City: Huntsville
State: Alabama
John, that's a great resource. Do you have any preferences on number of flutes? And coating? Seems that coating would be more important for non-wood.
PostPosted: Thu Jan 19, 2012 12:27 pm
I find coatings don't seem to do much with wood. I use 2 flutes for all my work. I didn't see an advantage with cutting wood . I like the extra chip room for the 2 flutes. It seems that the 4 flutes can fill up and block.
PostPosted: Thu Jan 19, 2012 12:37 pm
First name: Nelson
Last Name: Palen
Don't forget about taking several roughing passes if tearout is an issue.
