It is currently Sat Aug 09, 2025 6:26 pm
PostPosted: Tue Jan 10, 2012 7:15 pm
Last Name: Livermore
State: Minnesota
Just got the shop climate figured out and things are FINALLY stabilized.
Also bought a moisture content meter.
Humidity was REALLY high for a long time and now is hanging around 50%.
What readings should I be getting on my wood stash.
Right now all the tops in the stash are b/w 12 and 14% and the hardwood reads b/w 6%-9%.
Not ever taking readings before I don't know if these are normal, or high or low for wood that's been in the shop for over a year.
Thoughts?
PostPosted: Tue Jan 10, 2012 7:25 pm
As far as I know Moisture content meters do not give accurate readings on thin timber, which is why everone just lets it stabilize at a target RH
I would expect ready to build with timbers to be around 8%
PostPosted: Tue Jan 10, 2012 8:36 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Dave , did your moisture meter come with a species and temperature correction chart? For many woods, the reading on your meter must be re-calculated based on species. The industry standard species is Douglas Fir, measured at 68*Fahrenheit. Some woods that measure say 10% will have a corrected MC of 13%, while others may be as low as 8%. At lower readings the correction isn't that much, but the temperature of the wood will affect the true MC reading, and that must be calculated as well. I found a table that might help.http://www.comproteccanada.com/species.htm There are others that may show more species, and temp. correction tables. One thing that you can do is chart the moisture in a couple of pieces of wood on a daily basis for 14-28 days. You will likely see the readings go up and down for a while, and then remain pretty much the same, but the temperature must remain constant or the readings will not be accurate.
Alex
PostPosted: Tue Jan 10, 2012 9:08 pm
State: Minnesota
Thanks Alex.
I should have figured it would be complicated like that.
Will check out the link.
PostPosted: Wed Jan 11, 2012 1:38 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
This is the equilibrium moisture content chart that I use. I forget its source.
Temperature = 70 degrees F.
RH......EMC in wood
20......4.5
25......5.4
30......6.2
35......6.9
40......7.7
45......8.5
50......9.2
55......10.0
60......11.0
65......12.0
70......13.1
75......14.4
80......16.0
I have always heard that, but I seem to get pretty consistent readings from the thin wood I have tested. Even so, the best test to check for equilibrium of thin wood is simple, and requires no moisture meter.
Just lay the wood flat with one side exposed. If the wood curls, it is not in equilibrium. If the exposed side becomes concave, the wood is losing moisture to the surrounding air. If it becomes convex, it is gaining moisture. Flipping the wood over will cause the curvature to reverse. Repeat the process until the wood stops curling....then it is in equilibrium.
PostPosted: Wed Jan 11, 2012 3:26 pm
First name: Alex
Last Name: Kleon
City: Whitby
John, I am assuming this applies pretty much only to quarter sawn wood? I've never had a piece of cupped flat sawn wood correct itself by the flip method, and I have tried. [headinwall]
Alex
PostPosted: Wed Jan 11, 2012 8:38 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I weigh mine. When the weight stabilizes, they are at a stable EMC relative to the environment. So as long as your shop climate is proper and stable they are ready to go at that point.
Brian
PostPosted: Sun Jan 15, 2012 11:48 pm
First name: Peter
Last Name: Tsiorba
City: Portland
State: Oregon
I second weighing as a reliable indicator of stabilized RH. Gram scale, accurate down to .1g can be had on ebay for under $25. It can be useful for all sorts of other research/application around the shop.
Flamenco and Classical Guitars
Maker and Restorer
PostPosted: Mon Jan 16, 2012 5:50 pm
Last Name: Arnold
City: Newport
It applies to all wood. The reason for the cupping is uneven moisture distribution.
That is because it has moved enough to take a permanent set. That only happens during the initial seasoning....when the wood is dried from a green state. In my experience, once the MC reaches 12-14%, it responds as I explained, no matter how it was cut.
PostPosted: Wed Jan 18, 2012 11:49 am
First name: Corky
Last Name: Long
City: Mount Kisco
Great idea.... again, I learn things on this forum that I'm not even thinking about. Thanks.
Users browsing this forum: bobgramann and 46 guests
