It is currently Sun Aug 17, 2025 5:40 am
PostPosted: Wed Jan 18, 2012 12:51 am
There has been a lot of talk about how hard it would be to remove a bridge that had been epoxied on. I tried it yesterday. Because of all the talk here I was quite concerned about it. I used a 150 watt light and shielded the top from heat. After about 15 minutes of heat to about 170 F I was able to wedge a thin spatula in and remove the bridge without issue. It was very easy.
One thing that might have made it easy was that it was a koa top. I think spruce or cedar would be a little bit more of a delicate operation.
PostPosted: Wed Jan 18, 2012 2:05 am
Nope! I removed one from a spruce laminate top with a steam iron ...came right off!
PostPosted: Wed Jan 18, 2012 1:19 pm
I've removed a few that were pretty easy also, but keep in mind that there a many, many types of epoxy on the market. While some of them may be great for these types of applications, a lot of them are not. Once you find yourself dealing with the wrong kind, you'll know. :(
Jay
PostPosted: Wed Jan 18, 2012 8:20 pm
First name: Ringo
Yeah, epoxy joints are about a bajillion times easier vs yellow glue joints
PostPosted: Wed Jan 18, 2012 11:35 pm
Jay Lowe wrote:
I......... While some of them may be great for these types of applications, a lot of them are not.....
Which ones are not OK? How do you tell before using it.
PostPosted: Wed Jan 18, 2012 11:48 pm
All the ones I've seen formulated for woodworking will release in the same range as titebond. There are a lot of specialized epoxies that are much more heat resistant. You can usually find specs at the manufacturers web site or with a call to their tech dept.
http://www.chassonguitars.com
PostPosted: Thu Jan 19, 2012 12:52 am
What Kent said. A lot of the time you can just read the fine print on the package, and heat resistance ratings are sometimes pretty prominent on the packaging. There are actually epoxies rated for patching iron cylinder heads and patching cracks in your concrete driveway.
Over the years I've found a few guitars previously repaired with some of these. The only way I found to defeat it was chemically, and it wasn't fun.
Jay
Edit: These products are normally Methylene Chloride based.
PostPosted: Thu Jan 19, 2012 1:24 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Hammer and chisel method works well...Mike
Another day, another dollar.
Users browsing this forum: Bing [Bot], doncaparker and 17 guests
