It is currently Thu Aug 07, 2025 4:48 pm
PostPosted: Wed Jan 18, 2012 9:04 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I bought this old Stanley Bedrock flat sides 605 off of Ebay, along with a 604 in hopes to restore them both back to good useable condition. I started lapping on 80 grit but realized it would be countless hours of lapping before I got the soles flat so I took them both to a machine shop (both planes machined for $20!). The 604 turned out great but the 605 is out by about .012+" at the front left edge. The machinist says it was probably dropped. Check out pics below. I don't think I would want to machine the sole any further. Is this plane still worth fooling with? I'm just learning hand planes and I thought restoring a few would be a good way to learn how they work, and well, I just like restoring things. ;). Thanks for any input. Here are some pics...
Front end of sole, see left side...
Another pic with the problem area defined...
Problem area with straight edge and feeler gauge...
View from the top, just because...
PostPosted: Wed Jan 18, 2012 10:15 pm
City: chicagoland
State: illinois
you could always just treat it in practice as if it were 3/4" narrower then it is, and only put pressure on the "good" side. if you know how to weld you can fill it, then surface it again.
other than that, it looks pretty messed up
PostPosted: Thu Jan 19, 2012 1:05 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I'd get rid of it for a number of reasons.
PostPosted: Thu Jan 19, 2012 3:54 am
First name: Jim
Last Name: Hansen
Maybe if you drop it again, it'll bend back into shape. :D
Jim Hansen
PostPosted: Thu Jan 19, 2012 4:46 am
Sharpen the blade and try it. You might be surprised at how well it works and doing that is unlikely to cost you any more money.
A Plane doesn't have to be truly flat to work well, it just has to be flat in the right areas.
PostPosted: Thu Jan 19, 2012 4:55 am
State: Tennessee
I have several old Stanley planes that I bought for $20.00 or less. I would replace that one.
Looks like your machine shop did a nice job.
PostPosted: Thu Jan 19, 2012 5:57 am
For normal planing this sole will be perfectly ok (can't imagine how you could tilt it towards the front right edge!).
For joining top and back plates you will want to use only the completely flat side of the sole though.
Go for that restoration, those oldies (even the messed up) don't become cheaper.
PostPosted: Thu Jan 19, 2012 8:14 am
Don't Bedrock's have pretty thick castings, if you had it machined the rest of the way would it still be thicker than a standard Bailey plane? I've never handled a Bedrock plane before so I don't have a good sense of it.
PostPosted: Thu Jan 19, 2012 9:02 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I dont know if the Bedrocks are thicker than Bailey but it looks like there is plenty of sole left. Im just not sure; how thin is too thin?
I might continue the restoration and if it doesn't work out in its current state Ill take it back to the machinist. Thanks for your thoughts...keep 'em coming!
PostPosted: Thu Jan 19, 2012 10:00 am
First name: Patrick
Last Name: Hanna
State: Missouri
Yes, whether or not you continue to flatten that sole, it is already flat in the right places for most planing chores. It's definitely worth the effort to clean it the rest of the way. You can eventually find another that can be fully flattened, but don't get rid of this one.
PostPosted: Thu Jan 19, 2012 11:45 am
First name: Tom
Last Name: West
State: Nova Scotia
I would assume the plane body is cast iron. Cast iron does not bend from being dropped,it cracks. Cast iron can distort from internal stresses. I also assume the machine shop surface ground the bed. The machinist may have not noticed the dip when setting it up and when he did notice during the grinding process did not want to grind the bed any more to clean it up. To me tell someone it was dropped is just a cya statement on the part of the machine shop. Todd is right on, get it remachined to remove the .012-.015 and you will be OK. Good luck.
Tom
PostPosted: Thu Jan 19, 2012 11:57 am
First name: Orion
Last Name: Adcock
City: North
Zip/Postal Code: 76210
Don't throw it out. As others have already stated it is flat in the proper areas. Those are just fore and aft of the mouth also the toe and heel. Planing an area where the plane is completely in contact with the wood except the beginning and end of a stroke you'll be fine. Planing on edge will require staying on the flat side however as the toe needs to be in contact with the wood.
No one appreciates the very special genius of your conversation as the dog does.
Christopher Morley
PostPosted: Fri Jan 20, 2012 9:04 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Ok I will go ahead and restore it, based on the majority of favorable responses, and I just cannot toss aside such a classic hand plane. I will post pics when I'm done with the restoration. Thanks for your help.
PostPosted: Sat Jan 21, 2012 10:31 am
That stamped lever is there for a reason. There is a great deal of voodoo going round about flat. I have a variety of excellent planes, none milled, some flattened a bit and most re-bladed and easily adjusted with that lever. It is not barbaric to utter "flat enough."
PostPosted: Thu Mar 15, 2012 8:33 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I finally finished the restoration on my Bedrock 605. It took awhile to gather all the tools and materials needed to do the restoration (bench buffer, scotch brite wheels, battery charger for electrolosis, etc), plus squeeze in the time as it took several hours. I think the next one will go a lot quicker. It's ready for the next 100 years! ...........
before
before 2
Restored blade. Seriously sharp! Lapped and honed on Japanese water stones with a Veritas honing guide
After
After 2
PostPosted: Thu Mar 15, 2012 8:40 am
First name: Patrick
Last Name: Hanna
State: Missouri
Hi, Gil, Nice job on the plane. I'm glad it worked out for you. I'll bet a lot of folks will be inspired to clean up their rusty old hand planes after seeing your results.
Patrick
PostPosted: Thu Mar 15, 2012 9:44 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Thanks Patrick and Todd! Hey Todd, how do you go about baking the finish on using Duplicolor? For this plane I used epoxy enamel - the kind used for appliances (refrigerators and the like). I just sprayed on one coat and let it dry as per the instructions on the can. It looks great but it chips easy. I would like to try to bake on the next one, and maybe try a different spray paint such as the Duplicolor.
PostPosted: Thu Mar 15, 2012 10:33 am
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
Wow! Nice job, Gil!
+1 Todd, how do you bake the paint?? Low heat oven??
Chuck Kish
PostPosted: Thu Mar 15, 2012 11:04 am
Good on you, Gil. I love to see these nice tools kept in use.
PostPosted: Thu Mar 15, 2012 12:39 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Nice job. If you want to take it up one notch higher, try a Ron Hock replacement iron.
PostPosted: Thu Mar 15, 2012 1:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Please japan them. But send your wife away for the weekend, your gonna need the oven.
PostPosted: Thu Mar 15, 2012 1:30 pm
You will ruin it's vintage value if you re-japan or strip the original japaning in any way. Leave it as is. Looks great.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Thu Mar 15, 2012 1:59 pm
Gil, I am nearing the end of the process of restoring 6 Bedrock planes. It has been a very long and difficult journey, but I have a tip for you. The worst part is flattening the sole, for sure. Go to a shop that sells stuff for auto body work and buy some 40 grit, 3M "board sanding" strips. They are green and about 16" long and about 2" wide. If you stick these to a sheet of float glass you can make a long "runway" of abrasive. I needed a long runway as I had a 608 to deal with. The key here is that with 40 grit the sanding goes about twice as fast as with 80 grit and the 3M paper is designed for metal. Stay away from sandpaper designed for wood. I used a whole roll and got very little use out of each piece before the grit was too worn to use. Using the 3M paper will save you hours and hours of sanding. When you are done flattening them at 40 grit, do a polish with 80 grit and 120 grit.
I decided to "ruin" my planes and convert them to user planes instead of collector planes. They now look great and work great and no collector will ever be interested in them. Good luck on your restoration.
PostPosted: Thu Mar 15, 2012 2:22 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Hi fewarren - Thanks for the great tip, I will look into the 40 grit when I start on the 604. It seemed like a waste of time when I tried using 80 grit for wood, so I just took them to a machine shop. Even after the machine shop flattened my 605 I noticed it still could use a bit more lapping to get it perfect however the sole was flat within .0025". I also "ruined" these two bedrocks but I knew they would never be collector quality. I am thinking of buying a Hock or LN iron for each plane, maybe even an LN chipbreaker. Please post pics when you get some of your planes restored!
PostPosted: Fri Mar 16, 2012 2:25 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I wonder if you could turn that plane into a decent scrub plane? I'd certainly save it for parts at least. pizza
Users browsing this forum: bobgramann, Freeman, Ken Lewis and 17 guests
